Question about Toshiba Satellite 5105-S501 Notebook
My LAN Mini PCI Card 1410 not working
I just installed a Toshiba Wireless Lan Mini PCI Card, and specifically the PCI 1410 does not work, it appears that this well in the device manager, but not connected to the Internet, check this on the antenna, I just said that WIRELLES NETWORK CONNECTION IS NOT CONNECTED.....Wireless network unavailable. Any ideas,,,thanks in adavance Jorge
Upgrade toshiba tecra 8200 lan mini pci card
There are all kinds of lan cards available, go to Type: lan card, or pci lan card.
Apr 09, 2012 | Toshiba Tecra 8200 Notebook
I have a Toshiba Satellite 2450, Model PS245U-AAA14,SN Z2016206JU. Under Control Panel\System\Hardware\Network Adapters Toshiba Wireless LAN mini PCI card on Texas Instruments PCI-1410 CardBus...
Chances are you are using the win XP generic driver which may not be optimal for your hardware. Try downloading the correct driver found at the link below, install it and you should be set to go.
Good luck ;)
Feb 01, 2011 | Toshiba Satellite 2450-401 Notebook
Were is the wireless turn on switch?
It appears that there isn't an external switch to turn the WLAN off on the Everex NC1500 laptop (click here for the full manual). Here is a link showing you how to disable and enable WLAN card in WinXP (click here) if this is what you are trying to accomplish.
According to the manual (if your wireless isn't working) you must first install the WLAN driver before using the wireless connection. Info: "Wireless LAN module is similar to LAN module. You need to install software driver before using it. Please refer to Appendix B on how to install the driver." Appendix B INSTALLING THE WIRELESS LANDEVICE DRIVER Please follow the procedures below for installing the Mini PCI Adapter driver: Installing Wireless LAN driver for Windows XP 1. Click the Start button and then click Run. The Run dialog box appears. 2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe" 3. Click "OK" to implement the setup program to install this driver. 4. Click "Next" twice to continue the installation.
Hope this was helpful.
Feb 01, 2011 | Everex StepNote NC1500 Notebook
Need drivers for wireless mini lan card for Toshiba Satellite 1900-704,toshiba-satellite-m35x-s3491-intel-802-11b-g-mini-pci-wifi-driver-8-0-12-9000w2.html
copy this url and paste it in your browser and lunch.the download button for your driver will appear for your download.install/run setup.exe after ward and your problem would be fixed.
rate this solution please
Nov 24, 2010 | Intel Toshiba Satellite Mini-PCI Laptop...
Dell Inspiron B130--I have an internal Broadcom 1370 Wireless mini pci card installed. When installed the card everything worked. I had to reformat and reinstal WinXP from the hidden partition using...
Check Device manager to see if the wireless card is Enabled and working. If it has a yellow ? against it then reinstall the wireless PCI LAN driver.
Jul 08, 2009 | Dell Inspiron B130 Notebook
Driver needed This is driver location for vista
May 12, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Lan and wireless driver for toshiba a135-s2246
Unfortunately, the Toshiba Satelite A135-S2246 was never designed to run XP, only Vista. Which is why you can't find any drivers for XP. The nearest you can get is to find a laptop running XP SP2 that is using the same LAN (ethernet controller) and WLAN (wireless ethernet controller), and see if they will work.
Here are the drivers I found for XP (please check which one's you are trying to install):
Atheros WiFi card driver:
Intel WiFi card driver:
You will need to search for the card that you have.
LAN (ethernet controller):
You can pick third or fourth from top depending on your preference.
Please remember that Toshiba, Microsoft, Atheros, Realtek, Intel and especially myself accept no responsibilty for what may, or may not happen when installing drivers not specifically designed for your system. All that said, I hope it works for you.
Dec 05, 2008 | Toshiba Satellite A135-S2246 Notebook
Mini pci wifi for toshiba 1405 s-171 laptop winxp
As long as you have an open minipci slot, they should work. The antenna pigtails should plug into the card as well.
Oct 02, 2008 | Toshiba Satellite 1405-S151 Notebook
Computers & Internet Logo
187 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
