Question about Ovens
Install measurements for jenn air ww2780B
Install cut out measurements
5 Suggested Answers
SOURCE: Jenn Air electric double wall oven model ww2780B
A similar condition in our oven, finally resulted in an "F1" error message on the control panel/ keypad. A replacement of the control panel seems to be indicated. The part is available from several different jobbers: part # AP 4283616. A service call prompted our order of this part; hasn't arrived yet, but will post when in and working.
Posted on Nov 05, 2008
localwonder
  • 6784 Answers
SOURCE: I had an F1 Code on my Jenn Air WW2780B Double
Hi, This code is an indication of a fault that exist within the actual relay board. It is malfunctioning at this time, and should be replaced asap, if possible.This relay board is located inside the unit, mounted on the cooling fan shroud. Once replaced, the F1 code will be cleared automatically.
Relay board part number: Y04100261
Click here to view an exploded diagram of the cooling fan shroud, with relay board attached. The relay board is labeled number 9, and the shroud is labeled number 1
Posted on Oct 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Jenn-air double oven - model # ww2780b I was using
Your EOC electronic control is bad.
The part numbers are YO4100040 retail price $443.00
and part number YO4100264 retail price $208.00.
The repair requires both parts be replaced at the same time or risk damage to the EOC.
Posted on May 18, 2010
espressonist
  • 1711 Answers
SOURCE: F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Posted on Dec 26, 2010
Have a jenn-air jdr8895aab double oven. the oven panel just shorted out and have no controls for oven. can i just replace oven panel?
Call Jenn-air
1-800 # should be on the inside of oven
They may beable to send one to you if YOU can install or refer a local applaince repair shop for the unit ?
Oct 12, 2013 | Jenn-Air Ovens
F1 - E1
1.
codes except F1-E3.
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air double oven - model # ww2780b I was using the top oven. It started beeping and F1 came up on the screen.
May 18, 2010 | Jenn-Air JJW8230D Electric Double Oven
I had an F1 Code on my Jenn Air WW2780B Double Wall Oven, and turned both ovens on to heat up, which they did, and the F1 code never came back after that... so far. Could it be fixed?
Oct 27, 2009 | Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Aug 28, 2008 | Ovens
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
