Hi-- I paid to get answer on how to solve this about 30minutes ago. How long does it take to get an answer
SOURCE: Hi, do you know if I can install City Select maps
If you want to test the maps on your new Garmin you can do one of two things. Either you can copy the maps onto an SD card and then insert the card into your GPS. You can also connect the GPS to your computer with the USB cable that was supplied with you unit. Using whatever file manager you normally use with your version of Windows (Windows Explorer, Total Commander, etc), you will be able to see your Garmin GPS as another drive on your system. You can then copy your City Select maps over to your Garmin.
Once you have the maps either directly on your Garmin GPS or on a microSD card, you have to choose to use those maps. From the main screen of your GPS choose Tools>Settings>Map. If your City Select maps are compatible with your GPS they will show up in the list of maps. To make use of the map just choose it by touching the name of the map. Your Garmin will then load that map and display it. If your City Select maps do not show up in the list, or if you choose them and they do not load or give you an error then they are not compatible with your 1490T.
If you need anymore information or help please let me know. Thank you.
Testimonial: "That perfectly answers my question and save me from hours of additional testing. Thank you"
SOURCE: when I try to unlock maps the wizard tells me error communicating with GARMIN server
Try calling Garmin Support for assistance.
1-800-800-1020
