Question about GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker fill tube freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Side by side GE Monogram ZIS42NSB
Ice maker fill tube appears to be freezing. Tube from water valve to fill tube is blocked until I defrost it. Once defrosted it makes a couple of batches of ice and then freezes again. Water valve appears to be operating and delivering the correct amount of wate when detached from fill line. I replaced fill tube heater but it did not correct problem. New heater and old measured same resistance so I was not surprised that it did not correct problem.
When does fill tube heater activate? I can check to see if it is getting power if I know when it activates during the cycle.
Any other suggestions?
  • edenigris Jan 08, 2009
    GE Monogram ZISS42DCASS. Frozen fill tube, replaced fill tube, still freezing after 12 hours.
SOURCE: ge monogram zd115c automatic icemaker not making ice
Unfortunately, this has been a regular problem with mine for 6 years.  It started within the first week of installation.  I suggest calling GE and keeping track of when you called, who you spoke to, etc.  Every single part has been replaced at lest once and I am still without reliable ice.  I have been asking or a replacement since day one.  GE is not good on the customer service end of things.
Posted on Sep 15, 2008
tech master
  • 120 Answers
SOURCE: too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Posted on Nov 03, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Ice Maker that leaks water down the freezer wall
Ice makers have limit switches, thermal temp sensors, heating element and if anything gits out of order with these parts they will begin to do strange things like that. Now if you would like to remove it and have a look at the internal parts you may find the problem. They are a little easy to loose parts so be careful if that's your choice. A series of about six different cycles happen when they fill until the time it empties and begins again. They may cost less if you don't see what wrong to purchase a new ice maker. If you would like more help feel free to ask, Thanks, Sea Breeze
Posted on Apr 21, 2009
SOURCE: Water Dripping and freezing from icemaker fill spout.
I appears that no one offers solutions to the hundreds of requests on your website. I don't have enough time to wait for an answer from you folks.
Posted on Aug 04, 2009
  • 68 Answers
SOURCE: GE TFH27PRSA ice maker water fill tube and
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Posted on Aug 21, 2009
I get drinkingwater but the ice maker just wont make ice any more is something plugged where the water comes into that part that makes ice .Nothing looks broken only wont make ice?
SOMETIMES THE ICE FILL TUBE FREEZES UP, TO CHECK THIS REMOVE YOUR ICEMAKER AND LOOK UP IN THE FILL TUBE , IF IT IS THAW OUT, IF IT IS NOT IT MIGHT BE YOUR WATER VALVE,( YOUR WATER IN THE DOOR WILL STILL WORK) OR IT MIGHT BE THE ICEMAKER ITSELF
Jan 19, 2011 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water line freezes before it lets water into icemaker. Why? GE Monogram
Good day,
Usually caused by the dual water valve at the bottom rear of the machine.
If the valve cannot shut off completely after filling the ice maker, it will dribble down this tube and freeze it shut.
Needs the valve replaced. Common problem.
Nov 28, 2009 | GE Refrigerators
Not making ice . LED is flashing properly and put power to the valve in the back of the unit and it pushed water so appearantly something is not tellng the valve to open
Check the short black tube that is above the icemaker fill cup , to see if it is frozen . If so , then the water valve is " seeping " . Not closing completely and letting drops go thru which freezes in the tube . After a while , even if the ice maker calls for water , and the valve opens , it cannot fill the ice maker due to the frozen tube . Turn your freezer temp down , after removing as much ice from the tube as you can ( hair dryer may help ) . May take several days to thaw , since the tube runs between the top freezer liner and the outer cabinet . If not frozen , then the icemaker is bad .
Oct 13, 2009 | KitchenAid KSRU25CR Side by Side...
Ice maker fill tube freezing water dumpng all over floor
either the water solinide valve is faulty and allowing water to escape/ water pressure is to low or air is getting into freezer from the back of fridge freezer were the fill tube inserts
Sep 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
I ice maker keeps freezing in our side by side GE fridge.
This annoying problem can have a variety of causes. Check these four things first:
  1. Make sure the water supply is greater than 20 psi. If too low, thewater valve won’t seat properly and it’ll “weep.” Common causes of lowpressure are gunked-up saddle tap valves, kinked water supply line, andusing a reverse osmosis filter to supply water to the icemaker.
  2. Check between the valve diaphram and valve seat for sediment. If found, do not attempt to repair, buy a new valve.
  3. Check to see if the black, flexible portion of the fill tube iswrinkled, twisted, or kinked which can cause ice dams that block thefill tube.
  4. Find out if the water has been shut off while the icemaker has kepton cycling. This, too, can cause the fill tube to freeze up.
If all the above checks out and you’re still getting fill tube freeze-ups,then best get a service guy to take a look. It could be a complicated repair.
Jun 24, 2009 | Whirlpool ED2FHEXN Side by Side...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
369 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
