Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool duet sport Model: WFW8300SW00 is flashing f28
We replaced the drain pump, but it is still doing the same thing, any help or suggestions?
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport Model WFW8300SW00 stops after spin cycle
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: My whirlpool duet sport washer WFW8300SW00 does not work properly
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
Duet sport wfw8300sw03
try unplugging and plugging back in. a reboot of sorts.
i am not a repair man, but I own one too. good luck.
Jan 28, 2018 | Whirlpool WFW8300SW
I have a whirlpool duet sport that is displaying F28 code. I have replaced the ccu unit now what do I do. It fills but will not wash, drains but will not spin HELP PLEASE!
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is the CCU to order.
Here is the MCU to order.
Nov 03, 2012 | Whirlpool WFW8300SW
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Flashing F28
This is an MCU board unit failure.
To get the door to open so you can remove the clothes UNPLUG the unit from power source. You may have to wait awhile for the unit to reset.
However the unit should receive attention as this board is part of the main control. If the machine is under warranty it will be replaced free. This is common to this model.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Need a part number
The part number is W10160252. You can order the part at sears.com . The price is 131.10
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal De
