Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sylvania LD155SC8 audio missing on some channels...then noticed that the audio was missing ONLY on SAP channels. Referred to the owners manual and used the AUDIO button to toggle thru the available SAP, MAIN, & MONO options...settling on MAIN. Fixed.
I need remote control
Posted on Apr 12, 2009
I have a sylvania LD155SC8 and can't get it to get a signal. DVD works great. What gives?
Did you test the signal with another set?If so you may have a tuner
problem or a power suply, check the fuses.
Nov 04, 2012 | Sylvania LD155SC8 15 in. TV
On one channel...PBS we do not get any sound. Sound is ok on other channels and works on the other tv in the house
This television must have the ability to broadcast channels in SAP. Look for an SAP or MTS or AUDIO button on your Sylvania remote. The audio menu might be the place to find this setting as well. You want to remove the SAP and have the tv in either mono or stereo.
Sep 01, 2011 | Sylvania Televison & Video
My remote broke and some of my channels are on sap. and when i go to the menu there is no audio setting how do i put the channel setting back to stereo or mono
Hello
While receiving an MTS broadcast, press [Audio] repeatedly to to cycle through the available channel.
Main: Outputs main audio.
SAP: output secondary audio programme.
Mono: Outputs mono audio.
You must ahve remote control to change these, because only remote control have Audio button on it to control these. OK.
May 05, 2011 | Sylvania LC-155SL8P 15 in. LCD Television
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
I have no volume on certain channels
The most common problem with no volume only on certain channels is the TV is programmed for 2nd Audio, also referred to as SAP which is a feature activated to transmit a second language such as Spanish. If you push your menu button on your remote control you can toggle over to Audio Menu. Then find the feature that allows you to adjust the sound for Mono, Stereo or 2nd Audio (SAP). Adjust the menu to highlight Stereo and that should cure your problem.
Hope this helps with your particular problem.
Dec 05, 2010 | Philips Magnavox 42MF521D/37 Television
Under the channel it says SAP and no sound comes out on some channels,on other channels its says stero and works fine how can i fix the problem
I found this information in the manual, and perhaps it will help:
1 Switch the audio.
• Every time you press [AUDIO], the audio will
be switched as below.
MAIN : Outputs main-audio
SAP : Outputs second audio channel
MONO : Outputs mono-
Also the manual says this about SAP:
SAP
(Secondary Audio Program)
Second-audio channel delivered
separately from main-audio channel.
This audio channel is used as
an alternate in bilingual broadcasting.
Here is a link for the manual, in case you want to go over the settings. I'm thinking this is a setting problem in the menu, but it can be a physical problem with a cable line.
http://dukeelectronic.com/Manual/IWT3206.pdf
Of course it could also be a trickier problem, but check your settings, check the cable line with another TV if possible, and then contact ILO Support for help, in the event nothing fixes it.
Good luck, and hope this helps.
Dec 01, 2010 | iLO IWT3206 TV
Some of the channels on my Sylvani tv don't get sound. I have unplugged and re plugged both the tv and the cable connections. I also called the cable company and they told me it is nothing on their end...
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by SAP selected on your remote control. Make sure you have selected Stereo or Mono in the audio menu. You can find all of this in your owners manual ( which you can probably download if you dont have it). Good luck, John
Nov 19, 2010 | Sylvania Televison & Video
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
369 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
