Heatilator model gcdc60 heatilator gas fireplace will not light in power failure
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Heatilator Pilot Issue
Any pilot adjustment would be under a large screw with a flat blade slot in it. There would be a smalled flat blade screw under it. Warning: Too small of a flame and your safety device won't work.
READ MORE
Posted on Feb 09, 2009
  • 2558 Answers
SOURCE: intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Posted on Jan 02, 2010
  • 4736 Answers
SOURCE: Heatilator gcdc60 won't turn off
From everything you tried to cover, the problem lies in the wall thermostat. Repairing it isn't a good option. Replacing it is fairly inexpensive to do. Just make sure you replace it with one of the same voltage. Or if it's a millivolt control valve on the heater, make sure the replacement is for millivolt operation.
Hope this helped you solve the problem.
Posted on Apr 25, 2011
Pilot will not stat lite on gas fireplace
You may have one of two typical issues:
1. the thermocouple is bad and needs replaced
2. the control module may be bad and need replaced.
A certified and trained service technician can come out and diagnose the issue within a few minutes. There are numerous little tests that can be done to determine and isolate the issue.
Nov 15, 2013 | Heatilator Home
Is the gas stove Dovre model DV450, by heatilator, serial # GA384694 a B -Vent or Direct Vent?
Janny, generally with Heatilator gas fireplaces, the letters in the Model Numbers indicate whether it's a Direct Vent or a B-Vent. In your case, it's a Direct Vent. Had it been a B-Vent the Model Number would be BV450.
Hope this answered your question. Please be knid enough to rate my reply to you. Thanks.
Mar 24, 2011 | Heating & Cooling
I have a Heatilator IDV4833ILT propane fireplace, the pilot will light but not the main flame Thank you
there might be air bubble in the gas valve/ might need to change gas valve
Jan 18, 2011 | Heating & Cooling
I have a heatilator gas fireplace model gcdc60 and the flame is not high anymore. This fireplace has two settings low and high. The high setting is like having low on and the low setting is almost not...
Take a thin stiff wire and run it thru each flame port of the burner a few times each then if you can take a vacuum after setting it right on the ports-tap on the burner with a object while vacuuming it-if that does not work -is there a place that looks like a nut over each flame port? if so spray with a lubricant like WD40 to loose the nut and remove and clean flame ports that way and vacuum it then same way then
Sep 30, 2017 | Home
Heatilator gas fireplace orphis
Hi follow the gas line from the outlet of the gas valve to the burner injector is there you will have to remove the burner and change pilot injector aswell
Apr 22, 2009 | Stoves 1000DFDL Dual Fuel (Electric and...
READ MORE
Jan 04, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Dec 24, 2008 | Heating & Cooling
Heating & Cooling Logo
286 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
