How to reset the IP from a Planet Print Server PS-5P-S
My Print Server doesn't respond to BiAdmin. I don't know the IP address and I don't know if TCP/IP is disabled. How can I find out?
  • 624 Answers
SOURCE: Xerox Workcentre m20i - tcp/ip
Good evening niebs, The first thing I would do is eliminate the network connection as an issue. The easiest way (if you don?t have a network testing device) is disconnect the network cable from the printer and connect a laptop. Then configure the laptop using the same IP, subnet mask, gateway and DNS server IP you used in the printer and test for a good network. I would make sure I had Internet access on the laptop as well as the ability to ping. This test has the added effect of ensuring these numbers are in fact correct. If you have eliminated the network connection the next thing to check is the person who configured and maintains your network and servers. Checking with them will eliminate the possibility that they have setup the network to prevent anyone from connecting network devices without permission. By default I prevent my switches from allowing people to plug in other equipment that isn?t registered with me. That trick has saved me from a lot of problems over the years. You mentioned resetting the Network Interface Card (NIC) but I would go a step further, restore the factory settings on the entire machine and start from scratch. You might want to check with your network administrator to find out what you network switch connection speed is set to. If it?s set to auto make sure your print server is as well. If that doesn?t work try setting your print server to 10Mbps, half-duplex. I?ve had some problems in the past with auto not working correctly on print servers. If this printer is still under warrantee then I would get on the phone and contact the help desk, you might just have a lemon. Let us know how things go and please don?t forget to rate the posting.
Posted on Jan 05, 2007
SOURCE: HP JetDirect IP Address
how to assign the IP address to Hp color laserjet 2550Ln printer?
Posted on Sep 17, 2008
SOURCE: Reset Dell 1720dn network address to get back access to it?
Please have a look if you have Dell 1700 series laser printer. Please follow the instruction bellow to reset printer to factory default: 1. Power Off the Printer from the back switch from the back 2. Open Front cover 3. Hold Down “Continue” & “Cancel” button while turning printer on
se http://digg.com/hardware/How_to_Reset_Dell_1700_1700dn_1710_1710dn_1720_1720
Regards Anders.Thornberg.Qnetcom.se
Posted on Dec 29, 2008
  • 47 Answers
SOURCE: Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
Posted on Jan 06, 2009
pdouglasss
  • 125 Answers
SOURCE: installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
Select whether the TCP/IP protocol
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
Posted on May 26, 2009
How do I reset my keyspan Ps-4A print server?
Unplug power,
Pin in reset hole, hold in for 20 seconds
release and restart.
regards
dean
May 21, 2012 | Keyspan Computers & Internet
Lexmark Ed260 does not print
OK, if it's timing out that means the printer is not visible to the network. When you used the setup disc, you said it found the same address? What address does it detect? It will mostly likely start with 192.168.x.x. During the setup process does it offer to use DHCP vs a static IP address?
Do you know the IP addresses of the 8 machines on your network? You'll want to make sure the printer doesn't use the same address as that would cause an IP conflict and prevent it from working properly on the network. Preferably you'll want to use an address outside the scope. For example, if your DHCP server is set to give out addresses from 192.168.1.1-.20 then you should make the printer 192.168.1.21. Hope this makes sense.
If that still doesn't get you anywhere, connect the printer directly to a PC via USB and make sure you can print. It's possible it's an issue with the printer, but my guess it's just a network config issue.
Nov 10, 2011 | Lexmark E260dn Laser Printer
I am trying to get online but everytime i click the entrnet explorer it just says dns error i dont know what to do
A "DNS" server is a "DOMAIN NAME SERVER" -- you feed it a name, such as 'www.ebay.com', and it returns an IP-address. Then, the Internet "routes" your traffic to that IP-address, and eBay's web-server responds to your request, and sends a web-page to your IP-address.
A "DNS error" means either:
* there is no IP-address associated with the name, as you spelled it, e.g., 'ww.ebaay.co', or,
* your computer could not connect to the DNS-server, and so could not send the query,
* your computer does not know the IP-address of the DNS-server, and thus has "nowhere" to send your DNS-query.
Jul 19, 2011 | Computers & Internet
Hi, I have brought my dell laptop at work with vista operating system. It connects to internet networks wirelessly. I am trying to connect the work printer to my laptop but am not sure how to start. The...
hi,
you do not need a CD to connect to the printer, what you should do is gain access to the print server. this can be done by asking your network administrator. in a situation where you don't have one or the network is an open one, you have to connect to the printer network, open your ipv4 properties and select obtain an ip address automatically, do the same with the DNS server and you're good to go.
just so i'm thorough, after connecting to the print server / network, you can access your network ipv4 properties by right-clicking on the network icon located at the lower right corner of your taskbar, (the bar at the bottom of your screen) usually in form of two computer monitors. select network and sharing center after right-clicking. a list of wireless network should be available if there are more than one wireless networks in the area. select view status of the print server / network, click on properties, a pop-up box appears. be sure 'file and printer sharing for microsoft network' is checked, double-click "internet protocol v4 (ip/tcpv4)' select obtain an ip address automatically, select the same for the dns server below. click OK you're good to go.
note
once you are successfully connected to the print server, click on Devices and Printers from the start menu, select the printer and allow the drivers to be installed from the server. once that is done, you can right-click on the printer and select set as default. after this all you have to do is connect and print whenever you want to.
hope this helps
let me know if there's anything you don't understand or if this doesn't resolve it.
Jul 18, 2011 | HP LaserJet P4015 Printer
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
Jan 30, 2011 | Zonet ZPS2102 Print Server
No Ports available
The default IP in the D-Link router is 192.168.1.x
The default IP in the Edimax is 192.168.2.2
Your 3rd octet (the # after 168) has got to be the same for the two of them to communicate.
So, you can either reIP your router, or connect your PC to the print server and change it. The software for the print server should have a tool for finding the PS by MAC address, then you can go in and reset it to 192.168.1.x
Sep 17, 2008 | Edimax PS-1206U (PS1206U) Print Server
DP-303
Perhaps the XP firewall software is preventing PS Admin from connecting to the print server?
Jan 16, 2008 | D-Link DP 303 (DP-303) Print Server
Photo copier
Please confirgue the print server properly. Assign a particular ip address to it if possible. Then install the photocopier driver in computer and add the network port ip eual to the ip of print server. if it does not work install the print server driver if comes with it as a printer and assign it a ip.
Jun 19, 2007 | Toshiba (GD-1010) for e-studio25S, 16S,...
Can't find printserver on the network
Most Print Servers are by default on DHCP and if the PS is still on its factory defaults, it won't get an IP address because your computer won't have a DHCP server (unless u have set up one). Now, you can ask the person you got it from if he had ever assigned a static IP Address to the PS. Also, one of the reasons why your laptop won't detect the PS might be a software firewall installed. Please revert back with any other questions or observations. good luck
Mar 23, 2007 | Extended Systems Pocket Print Server
Edimax PS 3100A+ IP reset
First you must connect to the printer using lpt port. then that server automatically printing its information about it. example: IP address and ...
Aug 08, 2006 | Edimax PS 3100A+ (PS-3100A) Print Server
67 people viewed this question
jasbo
jasbo
