Question about Kitchen Ranges
Circuit breaker popping when stove top/ oven is on
I have a ge model electric range stove.  it's 4 years old.  recently, when i am trying to cook and use the stove top/ or oven/ or both- it will just shut off, popping the circuit breaker.  it will keep doing this over and over again.. after 7 or 8 times of going down to the circuit box sometimes, before i can get it to stay on.  what could be the problem causing this??
    Problem Solver:
  • 8 Answers
Thats how fires start when fuses keep blowing. Just use one at a time. Its probably over loading the fuse you may need a bigger fuse block. Call a local handy man if you havent already
Posted on Jan 03, 2009
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Frigidaire Stove model #PLEF398CCC oven reset
Hello - Does any part of the range work? Will the oven bake or broil? Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the cook top. If it proves to be ineffective, contact a professional to move forward accurately.
Nov 21, 2012 | Frigidaire PLEF398AC Electric Kitchen...
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
GE Spectra - burner pops & blows breaker
Either the burner has gone bad or the limiter on the burner.
Jul 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Ge spectra glass top stove.
Two possible reasons come to mind.  1. There most likely was a short circuit that activated the top unit. Was any part of the top glowing when you looked at it while it was crackling?
2. Be aware that glass tops CANNOT take as heavy a load of pots and pans as a STANDARD range can. The glass will crack. The stress can accumulate over a period of time and you will be left with the 4 am  madness dim experienced.
If anyone out there finds themselves in a similar situation, don't wait when  you hear the crackling. Pull the the range plug, or find the ranges circuit breaker in your electrical box and turn it off.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
No spark on all burners, oven doesn't work either
Give me the complete model # from the sticker on the oven and I will try to help.
Nov 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Switching from gas to oven
Your model stove is dual fuel. Which means that the burners on the top of your stove are run using gas, and the bake and broil (and possibly a warming draw) are run using electricity. So if you are cooking on the top of your range you are using gas, and if you cook in the oven you are using electicity
Nov 03, 2007 | GE J2B915SS Dual Fuel (Electric and Gas)...
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
293 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
