Question about LG Refrigerators
LRSPC2331 water doesn't work
We don't get water in the front panel any longer. We still get ice though am not positive it is generating more.
  • 1314 Answers
SOURCE: no lights or ice/water available
go here and get a new manuel for free if futher assistance is required reply to me yes its a good site http://www.maytag.com/support/manuals_literature.jsp
Posted on Jul 10, 2008
Yeramba
  • 5 Answers
SOURCE: Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Posted on Oct 14, 2009
SOURCE: ice maker and water dispenser front panel lost power
My door dispenser loses power and I can uplug fridge and plug back in and I have power, then after a few minutes the power goes off again.
Posted on Dec 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Posted on Jan 20, 2010
SOURCE: Ice/Water dispenser not working on
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Posted on Oct 31, 2011
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Our whirlpool ( ED22TW) no longer has water line attached, but we would fill up the ice bucket manually. The ice auger doesn't work when we push the lever on the front of the fridge. What's wr
On the freezer door at top where hinge is located a plastic hinge cover also covers a plug where many times the connection gets loose. Insure the plug is together firmly and all the wires are making contact. If that is not the problem then remove the ice bin push the freezer door light switch in as you press the dispense ice lever while looking at the motor coupling. Does it turn while pressing the light switch in as you also press the dispense button? If the first two test don't solve the problem then the micro-switch=> Micro-Switch-2162361-00564282
could be the problem. Let me know if I can answer any questions and I will try to get this going for you Thanks Sea Breeze
ED22TWXDN00 Parts Manual PDF
ED22TWXDN00 User Manual PDF
Jul 31, 2012 | Refrigerators
Whirlpool gold French door refrigerator ...ice maker stopped making ice. I THINK that my daughter left the door ajar (on the side with the ice/water dispenser) during the day. Came home to find water...
Oh yes. Shut it off let it drain and dry. When you start it up tho let the freezer cool for 2 days to be sure, then turn on the ice maker. 48 hrs will allow the unit to dry up any moisture you may have missed and all will be well.
Mar 04, 2017 | Whirlpool Refrigerators
We have a side by side whirlpool ice/water though the door water yes,but no ice production model number ED5SHAXMB10
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 11, 2011 | Whirlpool Refrigerators
Water does not dispense even though the ice dispenses. No water at all comes out , it is drier than a desert. What could be the reason the water does dispenser doesn't work?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 05, 2011 | Samsung RS2630WW Side by Side Refrigerator
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
My whirlpool refrigerator model # is no longer making ice consistently it will drop a few cubes every now and then. the lines are clear and no blockage what could be the problem?
Scale builds up in older icemakers and some of the cubes stick and don't eject.
Check your ice maker after it dumps and see if its keeping some of the cubes and
not ejecting them.
There are cleaners for the Icemaker. Call your local Parts Store.
also
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jun 23, 2011 | Whirlpool Refrigerators
Icemaker doesn't work....It doesn't fill with water???
Check your water supply ,make sure valves are open. make sure ice maker arm is in down position
Jun 22, 2011 | KitchenAid Architect 25.3 Cu. Ft....
I recently replaced my water filter on my Kitchenaid side-by-side refrigerator, model KSCS251, and since then my icemaker no longer makes ice, nor do I hear any water flow into it. The water, however, does...
Jun 16, 2011 | KitchenAid KSCS25FKSS Side by Side...
I have a Kenmore sise by side refrig on the left (freezer side) it ices up on the bottom
the drain is blocked.slime builds up in the drain line and then the water freezes in the line,unplug the fridge,melt out all the ice at the bottom of the back panel,you'll see a drain hole there,i use a steemer to blow through the drain line,if you don't have a steemer hit the hole with the hair dryer for a while,then pour hot water into the hole,if the water doesn't drain down the hole try using a turkey baster to blow out the line,or you can try to snake something down the drain hole but be careful,it's made of plastic,when you think it's clear pour hot water down the hole again if it doesn't drain keep hitting it with the hair dryer until the water drains down the hole,sometimes it takes like an hour to free it.
May 11, 2011 | Kenmore Refrigerators
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
