Question about Robin Subaru Electrical Supplies
Robin rgx 5500 generator run for 30 second s and dies out what is the problem?
My generator starts up and runs for 30 seconds and dies out. is it the carb or something else?
SOURCE: Coleman Powermate 6250 only runs with choke closed/air restricted
A call to Elliott Small Engine solved my problem - Oil Guard. I had checked the oil and it was just a little low but seemed well within the normal range. I was told to add more, bringing it just over the Full mark. It seems that the low oil protection system is very sensitive and shuts down the engine even when the oil is withing 1/8" of the mark. I added about 2-3 oz of oil and no more problems
Posted on Dec 16, 2008
  • 4 Answers
SOURCE: Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Posted on Jan 02, 2009
SOURCE: have a colemene powermate that will not stay started
Check the Oil. If it is low, the Low Oil cutout will shut the engine off after a few seconds. If the oil is full, try disconnecting the oil sensor. If this makes it run, you will need to diagnose and repair the cutout system.
Posted on Jan 21, 2009
JVRjr
  • 3 Answers
SOURCE: My Kohler Confidant IV generator starts and runs
Kohler generators feed the generated voltage back into the control circuit board to tell it to keep the fuel pump (electric) runing and the ignition on. IF there is no voltage generated (bad brushes or?) then the symptom you describe will occur. The motor runs fine, but it isn't generating electricity.
Jim Russell
Posted on Jun 15, 2009
SOURCE: Generac Generator won't stay running
I had this same issue with my NP 50G. I replaced the oil pressure & over heat sensor and fuel filter but the problem still existed.
After that I took the fuel bowel off the carb which had some dirt in it. Sprayed it with carb cleaner and that solved the issue. Hope this helps......
Posted on Oct 28, 2009
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Why does my briggs and stratton 310000 run rough on startup?
look for fuel puddling in the carb area (strong fuel odor on start up or after primering) may need a needle and seat valve
Jul 11, 2014 | GE 7KW Generator System With 50A, 10...
After starting it it dies seconds later like it's out of gas
Check the oil viscosity and level, and also make sure the low oil pressure switch isn't the culprit
Nov 12, 2013 | Briggs Stratton Portable Generator 305cc...
Onan 5500 marqui gen set stumbles on demand
Steve,
The microwave alone shouldn't cause a problem for the generator as even the most powerful models run about 1200 watts or about 10 amps. An air conditioner on the other hand, can draw considerably more power to run depending on BTU size; 15 amps and up is not uncommon (and even twice as much as that though only briefly when starting).
If these were the only things connected and on, the generator should be able to handle them - again depending on the BTU size of the AC unit. Generators state their capacity in Watts, but must of the devices we connect are in Amps. Calculating Watts in an AC circuit is complicated, but pretty close to the much easier Watts in a DC circuit for most residential settings. Here's how it's done:
Watts = volts x amps. Pretty simple stuff. Your generator is rated at 5500 watts. The microwave is say, 120 volts / 10 amps - which equals 1200 watts. The generator has 4300 capacity available now. Suppose your air conditioner is rated at 120 volts / 15 amps - which equals 1800 watts. 4300watts - 1800watts = 2400watts capacity is left. But, the starting current for the AC is as much as 25 amps for a few seconds (and once started drops back to 15 amps) - which means there's only 1200 watts capacity left. Add up the rest of the appliances you're running at the same time (TV set, Cable / Satellite box, stereo, toaster, lights, computer, etc.- you get the idea), and you can see how you might have exceeded the 5500 watts capacity of the generator for a few seconds. It's at these times that your hear / see the generator speed falter and sputter, lights dim, etc.. If this is happening a lot, you may need a larger or additional generator.
I hope this helps and good luck!
Dec 25, 2011 | Watts Onan Portable Generator - 5000 ,...
I have a Onan Microquiet 4000 in my Motorhome. It sat for a while and then I was unable to start it. I took off the carb and thoroughly cleaned it. The generator fired right up after that, it runs great...
Sounds like the float is out of adjustment, it's not keeping the bowl filled.If the float is not at correct height or the bowl was not placed back in the correct position it could show these symptoms , some bowls have a small indent on them and that recess should clear the float for proper movement of float. Or check to make sure that you have no water in fuel tank. Good Luck...
Mar 31, 2011 | Watts Onan Portable Generator - 4000 ,...
Robin RGX 5500 Generator owners manual
www.jackssmallengines.com/.../Robin%20equipment/MANUALS/GS0597B.PDF
www.jackssmallengines.com/.../Robin%20equipment/MANUALS/PUB_GS0597B.PDF -
There you go one owners manual.
Sep 26, 2010 | Garden
Electrical Supplies Logo
124 people viewed this question
Top Robin Subaru Electrical Supplies Experts
Steve
Gene Haynes
Are you a Robin Subaru Electrical Supply Expert? Answer questions, earn points and help others
