Question about Garden
Engine won't shut off! Replaced the shut off switch and it still won't shut off!
  • rwendelin Jan 11, 2009
    Thanks for trying but I just hooked up a cheap switch to shut it off and it is just fine.
    President:
  • 2,692 Answers
All the off switches do is to ground the spark either through  the primary or secondary. Make sure one side of the switch is hooked to a ground and the other to the primary (small wire) of the magneto.
Posted on Jan 11, 2009
Trying to locate fuel shut off switch
There is no fuel shut off switch on Oldsmobile or any other GM vehicle . When fueling the vehicle did you stop when the pump kicked off ? or did you continue to fill to top ? Flooded the charcoal canister an engine ! Is the check engine light coming on !
Jan 16, 2016 | 1999 Oldsmobile Intrigue
Engine won t shut off
Poor ignition switch .Replace it and check for the blown fuses & your problem will disappear .As ignition controls the current to ECU so if the ignition will still be transmitting the voltage to ecu with the key turned off so how will a engine shutoff? think it's logical.You have been tricked by mechanic as it's not the computer fault at all.
Dec 12, 2013 | Dodge Grand Caravan Cars & Trucks
Intermittent starter won't engage on mercrusier7.4 1988 boat engine
might be a burned spot on the starter contacts where the brushes power the motor.
tap the starter to see if problem goes away.
sometimes you can clean the contacts but that is a temporary fix.
Mar 11, 2013 | Cars & Trucks
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
see this causes and fix it. God bless you
Sep 28, 2012 | Dryers
Engine shuts down
The only way to know for sure is to hook a gauge to the rail and check the fuel pressure when it won't start.
Sitting for a few minutes and restarting is normally a sign of a relay or coil cooling off.
There should be a EEC relay that powers the dist module and ECM.
I know you said you have spark, but it could be something else
related.
Also, if you have spark at the right time and no fuel pressure, you should be able to use starting fluid to substitute.
I don't suppose you have dual tanks and the switching valve is the problem ?
Jul 05, 2012 | Ford Cars & Trucks
My lawnmower won,t start
Three things I know to check. 1. check for broken kill switch wire or loose connection on same wire. 2. check for loose or corroded wires on switch. 3.If this unit has a stator and mag polish the surfaces of both and check clearances.
Jun 21, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Front right side hit . replaced concerter and won't crank over /or start fuel pump doesn'd even come on when key is on ?
ricks63toy, I believe that Ford still uses what is called an inertia switch even in the hybrids. This switch will shut off in the event of an accident shutting off the fuel pump. This is a safety feature built into the vehicle. Seeing that this is a newer vehicle I trust that you still have the manual. If not, the switches are usually located in the trunk. Look on the side walls of the trunk and see if you can locate it. It is usually marked by a sticker. When you find the switch, push the red button down until you hear a click. This will reset the switch and allow power back to your fuel pump. Good luck with this.
May 17, 2011 | 2010 Ford Fusion Hybrid
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
