Question about Sanyo Audio Players & Recorders
I have a Sanyo AWm 2700 mini shelf system and the screen shows door and the CD system won't operate and I tried the reset as directed and it still does nothing. Suggestions?
  • 223 Answers
SOURCE: Problem with JVC stereo shelf system
It could be many things but if you put the disc in and you can hear the noise it makes while its scanning the disc then its probably the laser is mis-aligned. If you cannot hear any noise at all and it comes up with error after a while then it could be the entire laser unit needs replacing. Good luck.
Posted on Sep 26, 2008
  • 899 Answers
SOURCE: CD Player shelf will not open.
the door could be stuck or the cd laser mech. is stuck or the power circut for the motor that opens the door or the motor has become weak or ect..... there are many posibilitys but you need to listen for the motor sound or a click when you hit the button , if you do hear it then its stuck or the motor is to weak and needs to be replaced , or the circut isn't giving enough power to the motor
Posted on Oct 06, 2008
SOURCE: Multi-System Mini Component System Shelf System: MY SYSTEM WON'T PLAY THE CD, INSTEAD IT SHOWS ME T...
When I try to play a CD it gives me an er002 code. I have a CMS C333 system
Posted on Aug 10, 2010
  • 75 Answers
SOURCE: SC-AK78 CD Shelf System: MY PANASONIC MINI SOEREO SYSTEM SHUTS OFF WHEN I T...
STK-470-040 ic is blown and needs to be changed.
Posted on Aug 23, 2010
gopakumarg43
  • 74383 Answers
SOURCE: I have an old JVC
Hello
There are two possibilies for this faut. The first one is related with its Laser Pickup Unit, and the second one is related to its loading mechanism. If loading mechanism did not load disc properly to to the holding disc drive motor, disc wont play, and will be ejected as it enters into the system. i don't know, how old your system is, and how much it used so far. Anyway try first by inserting a head cleaning disc into the tray and play it for two of more time. if this does not help you try replacing the loading belt. You have to open your system to do this work. Loading belt can be located at the loading mechanism, fastened with its loading gear and loading motor. If this also does not help you, there is no other way than replacing the laser Picup Unit with same type and number. To repalce either belt or laser pickup unit, you have to open and disassemble the mechanism itsef to do the work. If you are not aware in electronics, and not so experienced in doing this type of work, get help from an other who knows these well. Most of the [90%] of components used in this section are made of high density plastic, and can be damged easly. If any wheel in loading gerar mechanis has broken teeth with it, also will poise this probelm. So it also should be checked.
Anyway you have to open and disassemble the mechanism as a whole. OK
Posted on May 25, 2011
How to play preset radio stations on sanyo AWM-660. Do you have to remember the preset numbers?
Once the stations have been stored in memory, you simply press the preset button for a particular station. Of course, you will remember which station was assigned to which button. :-)
Nov 12, 2016 | Sanyo AWM-660 CD Shelf System
Awm 660 bass
Does the manual list the part number of the remote? If it does you can search for a replacement on-line. If you are from the UK Curry's Partmaster has a good range of Sanyo remotes.
Sep 02, 2013 | Sanyo AWM-660 CD Shelf System
Need to connect a 6 cannel 9 pin audio cable subwoofer to a standard audio receiver. is there an adapter to make it plug into rca javks?
Nothing commercially available as the pin-outs are all different and 9 pin din is a non standard connector. Contact the manufacturer directly and ask tech support for pin out diagram.
Oct 27, 2011 | Sanyo Micro Shelf System AWM 3500 Shelf...
Can the AWM-660 Sanyo Shelf system connect to an iPod?
Yes but you need a adapter like one you would put in a car with a tape player.
Jan 18, 2011 | Sanyo AWM-660 CD Shelf System
Sanyo stereo AWM-2700U, cd player says'' door'' just blinking.
Press Eject button while tapping on the top. It should open
Dec 28, 2010 | Sanyo AWM-2800 CD Shelf System
The belt that rotates the cd tray is broken. How
Belts are measured by diameter and thickness. Some are sold on places like E-Bay, if you have no luck there you can try Chas Hyde & Son Ltd, they do have a website, they are also an authorised parts distributer for Sanyo.
Dec 12, 2009 | Sanyo AWM-2800 CD Shelf System
Clock set instructions for Sanyo stereo awm2800U
you need the remote to change the clock press timer am 1200 blinks press timer again for at least 2 seconds the hour blinks press tuning/time set plus or minus press clock adjust the minute will blink press time set to adjust minutes then clock adjust there you go...
Mar 10, 2009 | Sanyo AWM-2800 CD Shelf System
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
Doesn't recornize Cd's and won't play cds
I have a AWM-2700U (3 disc changer) that was doing the same thing. I removed the cover and found that the laser lens for the CD player had come out of it "slot". I cleaned it with alcohol and a cotton swab and replaced it in the slot and it has worked for the past 3 months since. Hope it works for you.
Aug 20, 2007 | Sanyo AWM-2800 CD Shelf System
37 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
