Question about HP Officejet 9110 All-In-One InkJet Printer
Cayan ink cartridge empty but now cartridge installed
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
It said replace black ink cartridge. It was indeed empty. I replaced it ...blank is fine but now it says cayan and magenta need replacing. They're both full. Won't print .
Try removing the cartridges and check if the electrical contacts are dirty. If they are, clean lightly with clean cloth. reinstall cartridges. If you still get the same message, turn the unit off then unplugging the unit, wait about 2 minutes. Then plug it back in and turn it on and see if it will reset itself.
Jan 21, 2016 | Brother Office Equipment & Supplies
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
My Brother MFC-685CW Printer Wireless doesn't recognise a new colour cartridge despite having cleaned the printer head. It also is not recognised by the PC despite reloading it. Help!! Troubleshooter...
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridge(s), it is possible another ink cartridge is empty and needs to be replaced or one or more of the cartridges are not installed properly. Complete the following steps:
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    1a. If the display continues to show NO CARTRIDGE, verify the cartridges are installed properly by uninstalling and reinstalling all four ink cartridges. Follow Steps 2a through 2f.
    1b. If "INK EMPTY XXXXX" (Xs = color, i.e. INK EMPTY CYAN) is displayed on the LCD, the specified ink cartridge is empty and needs to be replaced. Follow Steps 2a through 2f.
  2. To resolve an INK EMPTY message or to confirm the ink cartridges are installed properly, complete the following steps:
    2a. Open the ink cartridge cover. Pull the lock release lever(s) down and take out the ink cartridge(s). While you have the ink cartridge(s) out of the machine, verify the cartridge(s) are genuine Brother supplies with the Brother logo embossed into the side of cartridge.
    2b. Reinstall the ink cartridge(s). Lift and push the lock release lever(s) until it clicks into place and close the ink cartridge cover.
    2c. The LCD may then display:
    Did you change xxxxxx? Yes No.
    for the color(s) that was replaced. If this message appears, BE SURE to follow the instructions on the LCD to correctly select Yes or No. Select Yes if you installed a new cartridge(s) to automatically reset the ink dot counter for that color. Select No if you did not install a NEW ink cartridge(s).
    2d. After all the correct selections are made, the machine will then enter a cleaning cycle.
    2e.If the display again shows INK EMPTY XXXX, go back to Step 2 and follow the instructions to install a NEW ink cartridge.
    2f.If the machine did not enter a cleaning cycle and the display continues to show NO CARTRIDGE after reinstalling new genuine Brother ink cartridges, your machine may require service.
If your computer is not recognizing the printer you should uninstall and reload the drivers. You might consider downloading a new driver for your operating system from this site:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc685cw_us_as&Cat=112
I recommend bookmarking thihs site for future reference.
I hope this is helpful. :)
Dec 08, 2010 | Brother Office Equipment & Supplies
Photosmart c 7280--light cayan-- how do you clean heads-?
There is an option within your printers software " Head Cleaner "
Run that and it should fix your problem
May 20, 2010 | HP Photosmart C7280 Printer
I replaced the cayan ink cartridge, and it says there is no cartridge installed. I bought a second cartridge, and it still says that.
if you install the old empty cartridge and the message does not appear then the cartridge U have bought is not original
Jan 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Sep 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
MFC Brother printer will not print when Cayan is empty. Why wil it not print in black and white without it? And which ink is Cayan?
Cyan is the blue color ink, and it won't print when any color is empty so that you don't put air bubbles in the ink lines and ruin the printhead.
Sep 09, 2009 | Office Equipment & Supplies
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer Problems
Will it still print? Mine has said the same thing many times even after changing ink cartridges. I would just push the stop/exit then It will be ready to go. There should be no problem with printing after that.
Jul 11, 2008 | Brother MFC 420CN All-In-One InkJet...
HP Officejet 9110 All-In-One InkJet Printer Logo
66 people viewed this question
Ben Johnson
