Question about Panasonic Panafax UF-333 Plain Paper Inkjet Fax
ERROR CODES 016 AND 010
As soon as i start my panafax 322 display the following errors: Carriage can not move error code 016, and no recording paper error code 010.
  • Anonymous Mar 26, 2014
    cannot move carrier
    Genius:
  • 2,120 Answers
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Posted on Jan 03, 2009
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
My hp 7400 displays a message carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 20, 2010 | Office Equipment & Supplies
Display show check printer, error code ##322
the error code ##322 appears when the fixing unit is not working. the heater does not reach the specific temperature. check the resistance of the heater, or a pooor contact . but the best solution is replace by a new fixing unit
Aug 28, 2010 | Canon FAX-L200 Plain Paper Laser
Panafax uf-322 info code 016 carriage cannot move message. Is there a simple fix?
No simple fix.
Open the top cover, turn machine off.
Move the ink carrier to center, knock off the tower of dried ink with a letter opener.
Oil the chrome shaft.
Clean the plastic strip in back of the ink cart with soapy water.
Oct 05, 2009 | Panasonic Office Equipment & Supplies
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Pnafax UF-322
do you get the error code immeditely after turning it on or shortly after on
Thank You,
Mikey
Apr 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
Panasonic Panafax UF-333 Plain Paper Inkjet Fax Logo
439 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
