Question about Briggs Garden
Replaced stop switch and it still won't shut off!
Engine numbers: 10H902, 0113, E1, 05091255.
This engine is on an older Craftsman powerwasher.
Replaced the magneto and everything was fine. Then after about a week it wouldn't shut off. The stop switch that was in it wouldn't shut it off and the new stop switch won't shut it off either. What am I missing?
HELP!!!!
    President:
  • Briggs Master
  • 1,388 Answers
While attending college, I worked at a tool rental center and learned many tips and tricks from the mechanics. The problem that we heard the most from customers was that the machine would not start. Your your machine at least starts and runs fine, however will not shut down with the factory kill switch. Many times when replacing the mag. (spark coil) the kill wire would rub against the flywheel and break or over time the conductor wire will break inside the insulation. If you kill switch only has one wire, then all the kill switch does is short the mag to ground. Simple test is to remove spark plug, re-connect wire to plug, touch plug to engine and pull rope to observe spark, then short the tab on the magnito to ground, should be no spark. If you still have spark, coil is defective however good enough to run engine. Kill with choke or pull wire. If no spark with test, make new wire from tab of coil to kill switch or any switch that will short tab to ground. Good Luck
Posted on Jan 05, 2009
Where is the safety switch on clutch, when you let up on clutch the engine will stop. craftsman lawn tractor model no. 917.287030
On some of these, if the mower is in reverse gear and the blades are engaged,it will shut the engine off. Does it do it while in neutral?
Jun 18, 2017 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Briggs and stratton won't start
Without the model number of the mower and from the new engine it going to be a guess. As normally need to look over the electrical setups.
But there will be a need change some of the wiring. First make sure you are not applying 12V to the ignition coil. If you do you will destroy it. It is be grounded only to kill the spark. The wire going to carburetor does need 12v when starting and running the engine. It is an anti-backfire device which shuts off the fuel to the main nozzle.
Mar 02, 2014 | Craftsman Garden
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
My dls 3500 mower will not start at all, I charged the battery but the engine wont even turn. All the wiring and fuses seem to be ok
I had the same problem. I replaced the wiring harness for a short fix, corrosion in the terminals that connect to ignition switch. This worked for a while. Then replaced ignition switch this also worked for short time. Now I just open the hood to reach behind the ignition switch and wiggle wires while turning key to start until it starts keep wiggling to get good contact. If it won't stop after it starts, wiggle wires after you turn the key to off. It will stop.
May 29, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 15.5 hp ohv briggs n stratton on a craftsman riding mower when I engage the blades or let out on the clutch the engine dies out tried disconnecting seat switch ,replaced spark plug and fuel...
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
Aug 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I was using my sears craftsman riding mower yesterday and it was working fine...no issues whatsoever. I stopped the engine to get something and when I went to re-start it, the engine turned over just fine,...
You should check the seat safety switch,it may have stuck or is unplugged or it needs to be replaced.Any other safety switch that is unplugged or defective would keep it from starting.
May 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower model 917.273756. when
Sounds like one of your safeties are bad. Probably the seat switch (operator presence switch) under the seat. Pull the seat up and look at your switch. If you have meter then check for continuity when the switch is made.
Report back.
Mike
Oct 24, 2009 | Craftsman Garden
Replaced stop switch and still won't shut off.
Hi
When lever is turned to stop position look under the levers" support and see if there is established a conection with the wire from the coil wich kills the running engine.Also check the conductivity of that wire.
best regards savumihai71
Jan 03, 2009 | Briggs Garden
Garden Logo
712 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
