Question about Philips Televison & Video
My 52 inch projection wont turn on model #55p9161004
I replaced fuse and checked for reset button but did not locate one
Slinteriors
  • 8617 Answers
SOURCE: 1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Posted on Apr 10, 2008
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
Mr Alexx Sir
  • 12 Answers
SOURCE: TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Posted on Jul 29, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
  • 5 Answers
SOURCE: rca 52 inch projection
I had the same problem with the power button blinking 3 times and not coming on. I took this advice and changed the flyback 259296. That did not work. I also took the advice of superman276 and changed the cp150 and my tv works now. Flyback is $60 and the cp150 is $2. I pretty much wasted my money on the flyback.
Posted on Feb 01, 2009
MY RCA D52W20 52" WONT TURN ON!!!!!
Check the fuse on the AC filter board. If you trace the power cord into where it plugs in on the small skinny board located on the right side when looking in the rear there is a fuse on that board. If its completely dead I would suspect that fuse.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Reset button on 52 in rca rear p52940 home theater projection television located
this set does not have a reset button if there is a system lock out unpluging it for 3 or 4 mins will reset when pluged back in
if that does not help try trouble shooting the set ck the ac fuse and so on
Oct 24, 2009 | RCA P52940 52" Rear Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Rca flashing the menu screen
Check the buttons on the front keyboard panel. Try cleaning them if that's no help replace the panel or the buttons.
May 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch projection screen will not power up
Look for poor solder connections on the 4 bridge rectifier diodes. Looking from the back they to the right corner. Common problem.
Mar 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitach 55 inch 1998
have the poser supply checked sounds like it went out
Jun 28, 2008 | RCA P52926 52" Rear Projection Television
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Feb 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
