Question about Amana ABB2224D Bottom Freezer Refrigerator
Fridge not working
Relay clicks on&off,compressor feels warm,but not workingABB2224deq
hummm, click, every few minutes, gradually lost freeze and therefore frig coldness...no ice on fins, removed relay and shock, no loose rattle sound...
    Genius:
  • 3,422 Answers
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician.
Posted on Jan 03, 2009
    Brigadier General:
  • 8,619 Answers
Hi
It seems that there is a leakage in compressor gas due to which the fridge is not working properly. You need to get it refilled from a technician.
Thanyou
I have an Amana fridge model number abb2224dew. The compressor is very hot and the relay/capacitor is buzzing/clicking. The compressor will not startup. What is causing the compressor to heat up and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Maytag Model MBB2254GEW, bottom freezer: intermittently freezes and do not always feel cool air coming through the fridge. This is on and off for the last few months, where we find ice cubes all melted...
heatman101
May 24, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Fridge is plugged in and turned on, but motor seems to be trying to turn on, but isn't, and the fridge is very warm. There's a click, like it's trying, then after about 3-5 seconds there's another click,...
Greetings,
if your refrigerator is making a clicking sound every few minutes. It could be the relay burnt out. i would remove rear cover and locate compressor terminal cover and remove...pull of the relay,it will be the part that conects to two pins on the compressor...shake it, and if it rattles, its bad....
Dec 19, 2010 | KitchenAid Refrigerators
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
GE side by side Model GSS25JFMD 2 yrs old. Original problem was not staying cold. now I see if I unplug for half hour it seems to work right but sometimes freezes in fridge . I'm hearing a clicking sound...
These problems are saying relay/capacitor replacement and if that don't work then compressor replacement.
First change the relay and the compresssor cap. See if you have improvement...if not then you will need to have the compressor replaced.
Here is a tip about the relay and cap....
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Heatman101
Feb 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My 12 year old Whirlpool 167cm Free Standing Fridge Freezer has stopped working. There is still power to it, since the light comes on in the upper fridge compartment? Has the compressor gone? Coventry...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jan 10, 2010 | Refrigerators
253 55682402 Kenmore Side by Side Refrigerator Not Working. Freezer is not freezing and the fridge part is not cooling properly. Also water to ice maker and instant water in front of door stopped working....
How to check stuff>
Aug 21, 2009 | Refrigerators
Not cooling/freezing
"Pop" My friend, you already know the answer. "POP" relay, relay, relay..........You have a good sense of humor..
Jul 22, 2009 | Whirlpool GS6NBEXR Side by Side...
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Amana ABB2224D Bottom Freezer Refrigerator Logo
127 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
