Question about Kitchen Ranges
How do I remove the panel to change the light bulb on a C991N Turboair chimney hood?
4 Suggested Answers
  • 142 Answers
SOURCE: CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Posted on Jan 27, 2009
SOURCE: Cannot find a replacement bulb (Phillips X4J-40 watt)
I had the same problem and found bulbs that fit through elightbulbs.com. You have to look for a European base, 40 Watt, 120 Volt incandescent light bulb. They are about $3.50 each plus shipping. I bought two and they are excellent. I've ordered another 6. They are shorter looking than the original Phillips bulbs, but just as bright and you don't have to replace the sockets. Good luck!
Posted on Jan 29, 2010
Testimonial: "Thank You, I'll give these a try!"
Suzman
  • 642 Answers
SOURCE: How do you change the
Turn off power before attempting work on the hood. Bulbs are removed by turning counter clockwise. The manufacturer recommends using a latex glove or suction cup as the bulbs to tend to become stuck with prolonged use.
If you have the E-30AS hood the bulb will twist only a quarter turn before it can be pulled from the socket as it uses a clip-in type socket.
The E30S uses a screw-in type connector.
Download your user and installation manual here.
Posted on Nov 17, 2010
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
We turned the fan and light on our TURBOAIR S88 90 ST/ST 90CM CURVED STAINLESS STEEL CHIMNEY HOOD there was a flash from behind the buttons and now doesn't work is there a fuse that needs to be changed...
Sounds like the lamp has failed and maybe damaged the power switch. This, if installed correctly, will be fed from either a fused plug or a fused spur.
If it has been fitted incorrectly, no idea.
Jan 23, 2011 | Microwave Ovens
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 08, 2010 | Rangemaster Kitchen Hood
Need replacement bulbs for it, they are european style.
I have spent the last 3 months searching for them. Started in Italy and ended up in Michigan. No luck. The only choice you really have like myself is to replace the light sockets. That will also save you a headache when the bulbs need replacing again.
Apr 26, 2009 | TecnoWind 90 cm (approx. 36 in.) Classic...
Apr 03, 2009 | TecnoWind 90 cm (approx. 36 in.) Classic...
Lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Feb 23, 2008 | Thermador 36'' HTSW Series Stainless Steel...
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
