Question about Ovens
There is no heat from my diplomat adp3300 oven,what is the problem??
There is no heat from my oven,is the element or thermostat??
catriver
  • 878 Answers
SOURCE: Oven not heating
Gallow, Whirlpool put out a service flash on this model concerning the TCO located in the back. Regarding oven wont heat up, control panel normal. It has to do with the TCO (thermostat fuse) located just under the vent in back and it's tripping. Since you had the elements checked out, Im suspecting this TCO. Usually when these thermostats open, they are non resetable and you don't have any heat at all. The best thing to do is check this TCO with a meter. If it shows open, thats probably the culprit. They recommend moving the new TCO over to the left about 6 inches so it is not directly under the vent. You are going to need help pulling the built in out just far enough to get at the TCO. The part number for it is 4450934. The service flash is 22-647. Catriver...post back.
Posted on Oct 12, 2006
  • 6 Answers
SOURCE: Thermostat or Heating Element?
Check out our element replacement guide at: http://www.ransomspares.co.uk/fan_element_article.html
Posted on Feb 28, 2007
  • 1462 Answers
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Posted on Apr 16, 2007
  • 1214 Answers
SOURCE: neff oven u1421 not heating up
If you have an Ohm meter, then test anything you feel is failed. No sense in replacing good parts.
I am surprised that there is no wiring diagram somewhere on the unit, like in the control head, or on the top or back (most units built in the U.S. over the past 30 years have them. Don't know about UK, which is where I assume you are.).
Let me know! The overload on the back should have a red reset button. The thermal fuse has to be replaced if it's failed, and normally when it fails, the control head will not work. It usually does not carry enough current to power the elements.
Posted on Feb 01, 2009
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
Oven element has blown on my Diplomat ADP3310. I have replaced it but now when I select the grill the oven element heats up as well. Is this correct?
YOU have a wire crossed in the unit is the only thing i can think of. did you have to anything to the wiring or maybe you hooked up something backwards
Oct 25, 2014 | Ovens
My Diplomat ADP3300 fan assisted oven has been turning off when trying to heat up, but has now completely turned off. I am an electrician so have checked the obvious stuff but not sure what I'm looking...
I'm an electrical engineering technician college dropout. :) But i have had 30 years experience troubleshooting and working on electronics and appliance repair on occasion. I would look for the circuit board. It could have burned circuit traces or a failed voltage rectifier. Sometimes the whole board just needs replacing. Most boards that have relays have relays arcing and sticking inside at times too. If it isn't that then there is not much more than a thermal cutoff that could be the problem. They can be tested for open circuit easily. Also if the fan ever stops turning the thermal cutoff could be a safety feature to prevent overheating.
Nov 08, 2013 | Ovens
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
I have a diplomat oven - i turned it on this afternoon and whilst the fan revolves there is no heat coming from it! i tried the grill and this works fine and heats up! what could the problem be pls??
It sounds like the oven element is blown and needs replacing. If the oven fan and the indicator light are coming on it will be the element or possibly a burnt off wire at the oven element terminals.
Mar 12, 2011 | Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
I have a diplomat 4510 electric oven, the pilot light is constaintly on even when the oven is not on,the oven does not heat up, i recently replaced the element
If you have replaced the element, and it does not heat up, then I would suspect the thermostat as being the cause of the problem, more so if it is the oven pilot light that is on.
To be certain, you really need to see if you are getting a feed to the element when you you set the thermostat.
Hope this helps.
Jan 31, 2010 | Belling XOU592 / XOU593 Electric Double...
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
