Question about Whirlpool WED6200S Electric Dryer
Cabrio wed6200 fi sensor
F1 error code sensor light
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
  • 3 Answers
SOURCE: My Whirlpool Washer Cabrio model# WTW6200SW has a
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
Posted on Apr 19, 2009
  • 7 Answers
Your washer needs to be seen by an authorized servicer..... there is an (unofficial) recall which any authorized servicer is aware of. It will cover all parts and labor (Maynot include svc call if p/d is past 1st year.
The problem is in the RPS sensor and (or )the board. All of which would be covered by Whirlpool.
Posted on May 05, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
  • 122 Answers
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
Posted on Aug 22, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    We get a F1 error usually within the 1st 2 minutes of use however we just got it again with 17 min can you help us resolve this problem?
    This is a problem associated with the machine/motor control assembly or the pressure sensor system. Either the machine/motor control assembly is at fault or it is sensing an error in the signal from the air pressure sensor circuit.The first thing to do is unplug the machine for at least an hour to forcibly reset the control and eliminate the possibility of an electronic glitch. Click on the link below for the detailed troubleshooting of this error code should unplugging the machine does not address it.
    Error Code F1 on Whirlpool Cabrio/Kenmore Elite Oasis/Maytag Bravos Top Load Washing
    Aug 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    MACHINE DOES NOT WORK. Flashes F1.
    Aha the old F-1 error code. CAUSE:The control is sensing an error in the signal from the air pressure sensor circuit. There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed.
    I have some repair photos and those steps posted HERE
    Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio is showing a error code of F1 what does that mean?
    Typically, we're going to be looking at a pressure sensor failure here, although there are a few possible culprits. There's some pretty detailed troubleshooting here:
    http://www.managemylife.com/mmh/questions/195601-why-does-my-whirlpool-washer-model-wtw6500sw1-display-the-fault-code-f1
    Jul 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Fi light
    HE Top Load Washers
    Models:
    F1 Error Code
    WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
    MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
    Serial Numbers: CT01 - CU52
    A) Air leaks in the air pressure (switch/sensor) hose.
    a. Inspect the hose for cracks, pin-holes or loose connection.
    b. Replace the hose and harness assembly (W10058730) if it is compromised.
    B) Moisture in the air pressure (switch/sensor) hose.
    a. Inspect the hose for evidence of water.
    b. Replace the hose and harness assembly (W10058730) if water is detected.
    C) Lint or flashing in the air dome hose connection port.
    a. Inspect the air dome hose connection port for lint or flashing.
    b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
    the tub.
    D) The control needs to be replaced.
    a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
    with the air pressure system.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%@&^
    May 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio error code F1
    Have a look at this post. click here. Hopefully this post will inform you enough to get your machine fixed for free. Make sure you read all the comments down the page.
    -samson39
    Jul 19, 2009 | Whirlpool GSC9455 Top Load Washer
    F1 error
    It sounds like the tilt cut off may be to blame. If you put the bike into self diagnosis mode it will give you a code. This code can be checked and the offending sensor replaced. The tilt sensor in the tail piece is one sensor that turns the fuel pump off and so stops the engine.
    Jan 22, 2009 | 2006 Suzuki GSX-R 750
    Whirlpool WED6200S Electric Dryer Logo
    74 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
