Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Tv wont come on
It was plug and lighting hit the cable pole and now it wont come.
    Novelist:
    Champion:
  • 231 Answers
Hi, unplug your system from the wall then open the case and use a torch to see inside of the machine. locate your video card and examine the capacitors, these are the round things with silver tops on them. If any of them have a raised or bulged top or have leaked out the bottom then the lightning has over heated them. the only solution is to then replace the card. Goodluck. msityman
Posted on Aug 04, 2007
LG LB5900(UV BUSWLQR).It was hit in a storm through my directv. The red power light on the tv is on when plugged in but wont turn on.Whatd is the easiest way to find if it is the power supply board?
I would say it is the main board! The lightning went through the coaxial and hit the main board! I have had Lighting hit my sat, but only when it was grounded! LOL! so I learned my lesson! No ground since! You Have dish on a pole right? If I was You I would get a good, no great serge protector! one with coaxial connections and phone jacks! and hook the dish to it then out to tv! Not the cheap kind! Or It will likely get hit again! Best of luck!
Jul 11, 2017 | LG Televison & Video
I cant seem to power on
Try pressing and holding the button for a second or two. You may also try using a remote control to power on the tv
Jan 06, 2015 | Televison & Video
Bought a SHARP TV MADE IN DECEMBER 2002 Model NO. 32U-S60 from friend. Worked great until lightening hit our electric pole outside with it plugged in. Now it wont turn on. Can we reboot or something??
It is not predictable about the faults than might be occured due to a lightning stroke. It will be best to contact any service technician.
Aug 02, 2013 | Televison & Video
Purpose of the pole switch
The right hand drive have the bumper poles in front of the left hand head light. when the switch is pressed to the on position, the pole extends like an antenna and it has a green light on top of it. It helps to light up the area so you wont hit the curb and scrape the rims." __________________
Oct 08, 2012 | Toyota Cars & Trucks
My son just wrecked his 2011 Ford F150 at 60 mph hitting a telephone pole. He hit the pole so hard it broke the pole in half but the airbags did not deploy? What would cause this?
Is theTruck totally destroyed??? Some sensors, are designed to deploy, by movement to complete stop, in a portion of a second. I've been in 2 bad wrecks with my Maxda Protege. I time "T" boned a car. When it got hit,& was dead stop, they deployed. Light poles, (aluminum for sure) & some concrete poles are regulated by the US Dept. of Transportation. They are called "break aways". Years ago, poles were mounted on 3 - 4 ft concrete bases. The impact to the base would crush the car, if not the pole would "smash" thru the top of the vehicle. If that truck is repairable, I would have to believe he hit a "breakaway" & the breakaway did its job
Sep 07, 2011 | Ford F-150 Cars & Trucks
Edirol fa-66
1.i gained info about the mains supply data (9 volts 2 a, minus pole in the center pole of the plug) which is a quite exotic supply in comparison to standard devices with 12 volts an plus pole in the center pole ...
the fa 66 didn't work , when connected by 4 to 4 or 4 to 6 firewire cable .
my laptop only has a small 4 pole socket.
therefore i suppose that through this 4-pole socket and cable there was no current lead through.
after additionally connecting the fa-66 with mains supply AND 4 to 6 (fa 66 side) cable ... it finally worked.
the manufacturer should print all relevant data directly to the fa 66 device near by the socket und also print "FA-66" onto the supply ... because i own lots of alike-looking supplys and it's a drag to find out which ist good for what...
Mar 23, 2009 | Edirol FA-66 (FA66)
Firewire and playback on TV
I don't know it this will solve your problem but I'm using a 3 pole male plug and getting picture on the TV (but not great picture - see above).
Jan 01, 2009 | Canon ZR900 Mini DV Camcorder
My ps2 wont work on the TV
so back your tv input says yellow red and white should be sterio in unless its mono tv then just use white then in front hit ch down past 2 to go into inputs to see ps2 ok
Feb 10, 2008 | Sanyo DS31590 31" TV
Televison & Video Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
