Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips 60 inch projection hdtv
Its like you put a tracing paper over the word picture in the left upper screenand one word picture at an angle and moved it down to make it a double picture 1 inch off each other I cant get any help in Brownsville like they dont know what to do HELP PLEASE 956-621-2372 thanks
  • scott_ghilon Jan 05, 2009
  • gscrivner7 May 11, 2010
    It sounds like you have the word 'picture' burned into the screen(or the tubes). if this is the case, it's time for a new set.
  • Philips Master
  • 3,459 Answers
You have a convergence problem which is common on sets older than 5 years or so. At that age the chips start to fail and need to be replaced.
Here are the some common symtoms...
>>Screen looks 3D
>>One or more colors can't be adjusted when when using the convergence menu.
>>Screen is bowed in but stationary.
You will need to replace the convergence chips and resistors in your TV set. You can get them from several sources on the internet or you can get a complete kit + instuctions for you set from
Hope this helps,
Posted on Jan 07, 2009
    Problem Solver:
  • 18 Answers
O K, the misalignment is usually caused by a failure in the convergence output circuit. If the customer convergence alignment is no help then the outputs ic's are suspect.
Posted on Jan 06, 2009
I have a 60 inch philips rear projection tv that is only showing picture briefly when you turn it offf
Since the boards and most parts are not available for this model from Philips the only hope is to have a shop take a look, voltages and other checks MAY reveal what is wrong but I would not spend a ton of money on this set, was prone to a lot of problems and middle of the road as far as picture quality.
Dec 19, 2012 | Philips 60PP9202 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Pictures not lined up and angled
Sounds like your convergence is just out. First make sure the mirror in back is pulled out completely (if you have that model). Otherwise, there is a convergence feature on the menu that should fix it all.
Jan 03, 2009 | Philips 60PP9202 60" Rear Projection...
Picture behind a square
The problem is the close caption turn it off again and when the square leave turn the set off.
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
PHILIPS 50P8341 60 IN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
Dec 07, 2007 | Philips 60PP9202 60" Rear Projection...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Picture problem
Your set is having convergence problems, are the colors messed up in these areas or does it looks normal beside the arc? If the colors are out of line then convergence problems are on the way. Shut down and look at the convergence board for loose solder connections first, Then resistors that needs replacing. Last may have to change Convergence amps.
Sep 10, 2007 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
