Question about Frigidaire Dishwashers
Model fphd2491kfo not starting
Model FPHD2491KF0 pressing start button and does not start. If I press the Delay Start button it starts
  • 171 Answers
SOURCE: Kenmore 665 Ultra Wash FH141493
Hi daryano
I'm Harvey the Master Plumber
You want to know how to get the delay to work?
Most models work this way: Washing dishes the first time sets the favorites and the next time you start it the favs come on automatically provided you haven't changed the settings. So after the first use just hit delay and nothing else and when the dalay time is up it should work fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
  • 409 Answers
SOURCE: ESL 63010 will not start program
does your dishwasher have a timer button on it? sounds like the switch behind the button needs to be replaced.
Posted on Sep 13, 2008
fgainer
  • 54 Answers
SOURCE: Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Posted on Feb 02, 2009
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
  • 52 Answers
SOURCE: Kenmore model no. 587.14183401 blinking start light
you need to make sur there is water going to the machine first .....sometimes the valve is shut off .....under the sink
Posted on Jul 25, 2009
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
Won't start dial shows h:01
You have set the delay start. Press the button that says "finish in" or "delay start" (depending on the model) unit it is zero. Either that or you have entered the hardness setting and this should come off by just turning to the off position. Some of these d/ws aalso have a reset which is acheived by pressing two buttons simultaneously and this should be printed on the panel (dot under each button joined by a line) or hold the start button. (You haven't supplied the ENr so I have tried to give all possible scenarios) Post ENr if none of the above works.
Mar 19, 2013 | Bosch Dishwashers
The only thing working is the digital display and the input keys -- motor and heating element do not work. model 1196 toastmaster
Reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 16, 2011 | Toastmaster Kitchen Appliances - Others
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
How do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
Apr 07, 2010 | Hotpoint Ultima WD72 Front Load...
Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Dishwashers Logo
345 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
