Question about Horizon Exercise & Fitness
Treadmill smells hot and belt gets really hot after 30 minutes
Smells so bad i have to stop using it
dmichie
  • 76 Answers
SOURCE: smells like it is burning up when I use it!
You should unplug the machine, then remove the plate that covers the beater bar. Remove all debris from the beater bar, (strings, hair, etc.) and insure the belt is in proper position. If you have run it very long out of proper position, it may require replacement. Next before you put it back together remove any debis that may have collected in the intake behind the bar. You can also lubricate the bar with machine oil or WD-40.
Posted on Mar 09, 2008
  • 7 Answers
SOURCE: Treadmill smells HOT HOT HOT
Start by lubing your deck with a silicone oil or slipcoat
Posted on Apr 07, 2009
  • 159 Answers
SOURCE: Smells like it is hot or something is burning after changing bulb
Your tv is actually an Air eater. The tv itself needs a complete river of air (it looks as an exageretion) not really. I create this picture in your mind to help you to imagine all care you tv needs.
  1. Turn off the set. allow 20 minutes to cool down the set
  2. move the tv to the front and get access to the back of the tv then with a vacuum cleaner gets all dust out around the set
  3. make sure the air filter (refer to the manual) is clean.
  4. try to make sure the places were the air flows into the tv are clean and free of obstructions (back cover).
  5. finally all you can do outside the tv is done. Then when the tv is back its position make sure it "breathes" confortable. You tv has 3 fans inside (there is not a casualty)
The fresh air that goes into the system gets finally out really hot and smelly but as soon as the air flows thats normal for this tv. this is noticiable specially in hot seasons.
Posted on Apr 14, 2009
didik23
  • 35 Answers
SOURCE: it makes my clothes smell really bad
clean the filter.... after using the washer make sure u rinse it thoroughly with clean water
Posted on Jul 19, 2009
SOURCE: treadmill belt stopped
as soon as i press the speed button on my weslo m5 the belt seems to jolt forward then stops and everything goes off can anybody help on wot this problem could be
Posted on Aug 06, 2009
Stopped in Belt had been slipping smelled hot but motor was barely warm. Was 30 minutes into workout and machine stopped. Electric panel works but motor won't run.tilt works
time to lube the DECK belt, use WD-40 or grease. do it by each weeks. Try to loose the deck belt. in the way that you lift the belt by 2" with your finger. Otherwise, you must replace the belt+deck. See if the belt drive is to tight. And take time for maintenance the motor, replace the carbon brush+and lube the bearing.
Feb 08, 2015 | Nordic Track Nordictrack C1900 Treadmill...
Motor gets Hot
I'm not familiar with the treadmill specifically, but here is some general information that might be helpful. When a motor is under heavier load, it draws more current and therefore gets hotter. If for example, you were able to stop the motor shaft from rotating with an extreme load, it would draw what is called STALL CURRENT which is very high. So the problem seems to be that the load is out of specification. I'm assuming it would probably get hot if it was running with nobody on it as well. That would mean that the drive mechanism driven by the motor is not moving freely. If you can somehow decouple the motor from the treadmill drive system so that it has no load, and then move the mechanism by hand to see if it feels like there is a lot of resistance in the belts, pulleys or whatever drives the treadmill, then you need to lubricate to make it move smoothly. Or if you cannot decouple the motor, just look for all the bearings and pulleys and lubricate those but be careful not to get oil on drive belts or surfaces that require friction such as the surface of the belts or treadmill band. Don't ignore that the motor could get hot enough to start a fire so it is important to resolve this. It is possible that there are shorted windings and the motor is no longer good. If you can decouple the motor and run it no load, and it still gets hot, that would be an indication of such a shorted winding problem. Hope this is a little helpful. G
Feb 07, 2014 | Spirit Esprit ET4 Treadmill
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
I have Merit 710T that has recently begun to smell. I have lubricated the belt and had some problems readjusting the tightness and alignment but now that its aligned the treadmill gives me about 30 minutes...
see the video attached, lube TOO the rollers bearing front +back.
see the video how to adjust the deck belt.God bless you
However if finally the problem persist, test the input voltage motor see my personal TIPS, if there are Voltage at the terminals, the motor is faulty. Measure the output Voltage from the control board
for to input to the Motor, if there are NOT voltage from output the control BOARD is faulty, replace.
Oct 07, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
Pro form 635cw stops after 10-12 minutes.
please see the video and fix it .This happen because the lack of maintenance schedule in your equipment,God bless you
Apr 04, 2013 | Treadmill Doctor Proform 635Cw Treadmill...
It stops suddenly after about 30 minutes and it's getting worse. It's my treadmill sl20
check walking belt lube unser walking belt- check owners manual in maintance section. the start of friction problems
Jan 11, 2010 | Cadence Weslo Sl20 Treadmill Walking Belt...
After driving for around 30 minutes, the brake
That sounds like the "Porportioning valve" is defective.
You may want to go to your local library and check out a Chilton's, or some other repair manual for the "how to" to fix yourself or take it to a tech you can trust.
Dec 28, 2009 | 2003 Hyundai Accent
Exercise & Fitness Logo
265 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
