Question about Kenmore 63942 Dryer
Replaced heating element still no heat
Dryer not heating replaced element checked circuits and fuses
  • Anonymous Jan 04, 2009
    Kenmore model # 86870100
    No hot air coming from dryer
  • 706 Answers
Did you check and/or replace the thermal fuse in the dryer? In many instances, that opens and disables the heating system...
Posted on Jan 03, 2009
No heat
Hello there:
There's no heat If your dryer doesn't heat, check these: Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block
May 13, 2010 | Amana DLE330RAW Electric Dryer
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 | Dryers
Dryer stopped heating. Runs fine but no heat all of a sudden.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Jan 05, 2010 | Whirlpool Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
No heat.... how do I locate the heating element
Jan 02, 2010 | Kenmore 700 6973 Dryer
No heat gas kenmore gas dryer
Dec 31, 2009 | Kenmore Dryers
Not heating. I was using the dryer without the vent and it stop heating.
Dec 31, 2009 | Roper RGX4634KQ Gas Dryer
Dryer will not heat up
Hi fairiesinfli,
Check the below:
Heating element
Thermal fuse
Regards
R.K.
Oct 22, 2009 | Whirlpool Dryers
Not heating
Heating element
Thermal fuse
Wiring
May 20, 2009 | Dryers
Gas dryer is not heating
Heating element
Thermal fuse
Wiring
Thanks Repairclinic
Aug 25, 2008 | Dryers
Kenmore 63942 Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
