Question about Proview HX303 30 in. HD-Ready LCD Television
Proview rx-276 no picture
When turn tv trying to to come on blink shadow picture but no picture that anybody know where i can find the connector or where the picture tube is connect
4 Suggested Answers
  • 8 Answers
SOURCE: proview rx 326 model 3200 tv sound but no picture
If the sound is working, I doubt the power supply is at fault. You can check with a simple voltmeter - red is positive, black negative - there should be 24VDC. There is an on-board regulator to drop the voltage for the CPU, etc, . THere is a green LED on the main board, so even if you don't have a Voltmeter, there is a visual indication that the power supply is somewhat functional.
I found a poor connection from the 24V power supply over to the inverter boards. I re-crimped the IDC connectors to the 24V supply and all was happy-town.
Posted on Jun 05, 2008
  • 541 Answers
SOURCE: No video but I do have audio
It really doesn't have a reset for the picture. I would be looking at the inverter and power supply. If it is four years old most likely it is the inverter. The inverter is on the left side looking at it from the back. Have a repair shop check it out for you. Thanks
Posted on Oct 24, 2009
bugoy31
  • 1238 Answers
SOURCE: when I turn the tv
that problem is on the back-light lamp of your LCD TV it is busted or weak need to replace it
Posted on Mar 09, 2011
My proview rx326
It should have inputs for analog AND digital.
http://thebooksout.com/downloads/proview-rx-326-user-manual.pdf
This site seems to have it, but might be a charge.
Sep 26, 2017 | Proview Televison & Video
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2014 | Proview Televison & Video
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
Jul 28, 2012 | Proview PA-32JK1A 32 in. LCD Television
No video but I do have audio Proview RX 276 TV 4 years old How do I reset system? Doug
Oct 24, 2009 | Proview HV-177 17 in. HD-Ready LCD...
Turns off and on
If it happens at a certain time every day, make sure you do not have the sleep and wake timers on.
Mar 08, 2009 | Proview PA-32JK1A 32 in. LCD Television
No picture but there is sound
This may be the problem click on your remote source button and see what is checked on the blue sceen that pops up...it may be on the wrong setting... I hope this helps, Ken, Attica, NY
Nov 24, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
May 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Proview HX303 30 in. HD-Ready LCD Television Logo
115 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
