Question about Linspire Five-0 for Linux
Display configuration problem
Running older Desktop Compaq With new Envision LCD monitor. Ijustinstalled Linspire Five-O and need to shrink desktop down by about20%in order to fit on display. I tried everything includinggoinginto display menu. Can you help?
Thank you.
Tim
  • 66 Answers
Check your VG adapter if it is properly installed. if it is onboard VGA install it by inserting your CD Driver to the CD ROM then follow the instruction the pop.up on the screen of your compouter. the same with if your VGA is not onboard you muyst chekc if it is properly installed.
Posted on Jan 09, 2009
How do i get rid of the permanently stuck brightness display on centre of my philips lcd monitor for my desktop
This is one for your Envision Web site - go there, look for support, and then either find a similar question in FAQs or find a link to contact them to ask for help. Especially if this can be considered still under warranty.
It is usually done with one of the buttons at the bottom or side of the monitor itself, like options or configuration. You might have set it that way by accident.
Cheers!
-a.
Apr 09, 2012 | Envision Monitors Philips BDL4251V 42 LCD...
HP 7540 crt monitor shrinks to a horizontal line
It would be more economical to purchase a new or used LED/LCD display rather than wasting money on an old CRT monitor.
Feb 22, 2012 | HP COMPAQ 7540 CRT Monitor
I have a Silicon Image 164 ADD DVI card added to my HP desktop DVI-D access card in an effort to get a dual monitor configuration. I get an exact clone in the second monitor. I have an HP compaq desktop...
If the Intel graphic card is part of the motherboard, you need to disable this in the BIOS. You need to install the Silicon grpahic driver, then you will be able to configure the screen resolution etc for each monitor.
Jun 10, 2009 | HP Compaq d530 CMT PC Desktop
Frequency out of range, it read , please change the display mode to 1440 + 900 with 60Hz.
You need to Set the Desktop Display Settings to match those advised by the monitor... in other words, your desktop's resolution settings aren't supported by that monitor, so right click on desktop, choose settings, and change the resolution (1440 x 900 ) and set the Refresh Rate (60 Hz).
Apr 20, 2009 | Envision 19" Widescreen Flat Panel LCD...
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Linspire 5.0.59 cannot open unbutu
File format should be a . iso opened with power iso or120% unbuto need to be on a **** to run or boot from
Get it here http://www.ubuntu.com/
Jan 25, 2009 | Linspire Five-0 for Linux
Envision EN 5100 E with Dell Inspiron 530...
you can try to reset your display settings... try 640x480 resolution 60Hz refresh rate this can be done in the control panel under display---settings tab..
good luck.if that doesn't work I would just return it and buy a viewsonic LCD here the price was just marked down from $260 to $130 bucks
Jun 25, 2008 | Envision H170L Monitor
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Linspire Five-0 for Linux Logo
44 people viewed this question
Top Linspire Computers & Internet Experts
David Payne
David Payne
Are you a Linspire Computer and Internet Expert? Answer questions, earn points and help others
