Question about Sony PlayStation Portable (PSP) Console
Broken Screws PSP Help Needed ASAP!
Hi, the switch to open the UMD door on my PSP was not working so I read on this site that I had to open it up and see if the switch had 'jumped'. However, I was not told what screwdriver to use and clumsily stripped the heads of two of the screws, (the bottom one on the back case and the top left one behind the battery). I've tried many methods of extracting including using screw extractors, drilling holes etc. but none seem to work as the screw is very very small! If anyone could help me with this problem I would be very grateful. All suggestions welcome! Many Thanks!
  • LuQz MuKz May 17, 2007
    Thanks for answering but I can't take off any cover because the screws won't let it come off. Any other solutions, please?
  • 34 Answers
HI THUGANGLE I UNDERSTAND YOUR SITUATION WHEN THE SCREWS ROUND OFF THEY ARE NOT EASY TO GET OUT CAUSING LOTS OF PROBLEMS IF YOU CANNOT GET HELP ON HERE PLEASE GET IN TOUCH WITH ME ON THIS WEBSITE MY SHOP WEBSITE AND I CAN ARRANGE TO SORT THE PSP OUT FOR YOU ............. WWW.CONSOLEREPAIRANDPLAY.CO.UK
Posted on May 30, 2007
SOURCE:
When we turn it on, we can't get a game to start. Is there a way to reset it and start fresh?
Can you clearly tell me the problem? Did you do these steps?
Switch on PSP>insert UMD>wait for auto start
(I am guessing that your PSP detects a game once it is inserted)
In addition, what series of PSP do you own? (it has to be a PSP1000, 2000 or 3000- if you are in the US, the serial will be 1001, 2001 or 3001)
If the UMD is not detected at all, the UMD sensor maybe broken.
In a PSP1000, there is a small sensor (which looks like a grey 'tooth' that sticks out from the motherboard when you open the UMD door and peer in) and if this is broken, a UMD will not work. This sensor signals to the motherboard that there is a UMD inside. On 2000 and 3000 PSPs, there are two sensors; one grey 'tooth' and another that is located near the UMD door. This signals the motherboard that the UMD door is closed. If one of these sensors are broken, a UMD will not work.
I hope this helps you out, please post back and let us know!
Dec 28, 2010 | Sony PlayStation Portable (PSP) Console
My sony psp phat umd not read
If it's for all UMD's, you should check something out. Open up the UMD door and leave it open for this test. There's going to be a little lever inside that you need to push down. Looking at the UMD door from behind, screen facing away from you, the little lever is going to be on the top right, you'll see it. Push it down, while the PSP is on and look at where the laser is. You should see a red light coming from it, and it'll be obvious. If you don't see the light, your laser is broken.
May 06, 2010 | Sony PlayStation Portable (PSP) Console
My son's psp (the older fat version) has stopped reading discs
Not sure is this actual PSP or play station. If it is Play station It is very possible that there is problem with laser that reads disks. Try to by PSP cleaner and run it and this might fix the issue.
Dec 29, 2009 | Sony ACY-BR81/OB
My psp umd drive will not work, no clicking... no spinning sound... i have not dropped it, what do i do?
Open the umd door there is a small switch in the upper left corner if the tip is broken off of it it wont play umd's .The switch tells it the door is closed.
Dec 12, 2009 | Sony ACY-BR81/OB
Psp umd cover
Your umd door cover is located on the top of the PSP there will be a silver or black switch there. Switch it to the right it will automatically retract and open the door.
Nov 11, 2009 | Video Game Consoles & Games
Psp always read from umd,making it hang
Hi! I incounter this problem as well even without UMD its still loading and even I disable auto-start UMD still same so I tried reflashing the software but still same problem so I discover the solution before you turn-on your PSP try to open your UMD cover you'll see it will load faster then close again the cover once you see the battery and clock icon... The problem that causing this is the switch inside the UMD possible its stock-up or spoiled already!
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
PSP hanged when switch on. The usual screen appears but without the menu icons except for a small circle at the bottom right hand corner which keeps spiinning. Icons will only appear when I open the UMD...
conect your psp to you pc/lap top and find a default setting for your psps this are just like other peoples psp saved dater try that look on game sites and console cheats sites
May 09, 2008 | Sony PlayStation Portable (PSP) Console
UMD door switch will not open the door
The switch has a small plastic tit that moves a thin metal piece to the side so that the hook on the UMD door is released. If the little tit is broken off it cannot move the metal slide. The metal piece is not likely to break. If it feels like the slide switch is not pushing anything when you slide it, remove it which ever way you see fit. Use a small nail or tack to slide the metal piece inside towards the center of the PSP. This should open the umd door.
Nov 24, 2007 | Sony PlayStation Portable (PSP) Console
Psp
Hi Jleew,
You should check to see if another UMD will work first.  Also try them in another PSP.  If your sure your PSP is not reading Discs, then and only then, Clean the Laser lens carefully.  Using a strong flashlight and magnifying glass, look into the UMD drive with the UMD door open and look for debris like hair or lint, and also dirt and dust.  A black switch pokes up on the left inside the UMD drive.  Its a little black stick.  When you press down on this Black stick, your UMD disc motor should spin for  second or two.  The UMD laser lens should light up when your press this switch.  If any of this does not happen, you need to replace the UMD drive. If you need someone to do this which if you have never done it, you need some knowledge big time.
I can do this for you if you're in the USA for $55 including a New UMD drive, REturn Shipping, and 90 day warranty. Contact Repairtech@playstationclinic.com
Oct 23, 2007 | Sony PlayStation Portable (PSP) Console
PSP wont read games(UMD)
try reset default setting.  it worked with my psp.
inin
Oct 08, 2007 | Sony ACY-BR81/OB
Sony PlayStation Portable (PSP) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
