Question about KitchenAid KHMS105E Microwave Oven
Internal venting of KitchenAid Microwave oven hood combination
How do you adapt the KHMS105E to a recirculating air filter rather than an external vent?
  • KitchenAid Master
  • 9,098 Answers
That info is in your installation instructions, which can be found here.
Posted on Jan 03, 2009
Does the maytag mmv1164ww1 micro/hood combo require outdoor venting?
No .. it can also be recirculated . you will need charcoal filters if you do so. There is a specific charcoal filter for each microwave hood. Any appliance part dealer would carry it ( you will need to give them the micro hood model number ) or you can order them online through Whirlpool parts website ( whirlpool owns maytag)
Mar 14, 2011 | Microwave Ovens
The microwave doesn't seem to be bringing the air up into the vent for exhaustion outside. It's brand new.
I presume that you can hear the fan running? If so, most over the cook top microwaves have an option to vent to the outside or simply recycle through the filter and vents above the unit. If you check your manual there should be instructions on how to change this configuration to suit your situation, but it likely needs to be done before you install the microwave.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137234.pdf
The above manual shows how to reconfigure the microwave from recirculation (as shipped) to external exhaust setup on pages 4 - 5.
Oct 10, 2010 | Frigidaire PLMV169DC Microwave Oven
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Eric
Oct 29, 2009 | Whirlpool MH7140XF Microwave Oven
Recirculating over the range micro does not take care of steam
Mayny reason. Does it vent outside? If not you are not getting a great amount of air flow. Are you filters clean? Dirty filters will stop max air movement. These are not the best machines for moving air but they sure are great spacemakers. Not sure if this can be fixed by any means other than a true vent hood.
Jan 26, 2009 | Maytag MMV4205 Microwave Oven
Does Microwave KHMS105E have a fuse
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If the fuse is out, it will be totally dead. Is that what's wrong with yours?
Feel free to reply back if you still need help.
Apr 08, 2008 | KitchenAid KHMS105E Microwave Oven
Exhaust problem
you got to have make up air from someplace! the microwave cavity is sealed so microwaves don't leak out. [door seal] why would you have a grease filter on a microwave? is this a combination range vent hood AND a microwave exhaust system?
Dec 29, 2007 | Maytag MMV5165 Microwave Oven
Front vent on JMV8208A Jenn-Air Over-the-range microwave hood keeps opening
There may be an option to turn that off with the keypad, but your best bet would be to contact Jenn-Air.
The manual will have their contact info or you can see: http://www.jennair.com/content.jsp?name=contact_us
You can download the owner's manual and installation manual here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208A&siteCd=JA_EN_US
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 03, 2007 | Jenn-Air JMV8208A Microwave Oven
Microwave Ovens Logo
394 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
