Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
50.3 fuser Error turn off then on - HP LaserJet M1522nf Multifunction Printer (CC372A)
2 Suggested Answers
vladmototole
  • 226 Answers
SOURCE: 50.a fuser error
Change the fuse!!!
Posted on May 21, 2012
Konica minolta 240f error code 18 stands for what
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Apr 07, 2018 | Konica Minolta Office Equipment & Supplies
50.0 fuser error
SOLUTION: Follow the steps listed below:
  1. Turn the printer off and unplug it for 30 minutes; then turn the power back on.
  2. Try a different power cord. DO NOT use extension cords to plug the printer in.
  3. Remove the surge protector or UPS/CVT device and connect the printer directly to a power source.
  4. Try a different electrical circuit. There could be an issue with the line voltage going into the printer from the power source.
  5. Turn the printer off and unplug it. Let it sit for 30 minutes to let the fuser cool off. Carefully remove the fuser; IT MAY STILL BE HOT USE CAUTION. Examine the fuser, if any damage is apparent the fuser may need to be replaced. If no damage is noted reinstall the fuser, plug the printer back in and power it up.
For More info Source... Hp Error Code 50 Service Errors 50 Fuser Printer Repair
Thanks,
HP Printer Support
Jun 26, 2014 | HP LaserJet Pro P1102
Getting an error code 50.9 "fuser error" went through the steps in the help screen and turned printer off/on. Help!
A 50.9 fuser error is one of the most common errors. If you get a 50.x error, you can try turning the power off and on and reseating the fuser but in almost all cases you will need to replace the fuser.
Do not forget to rate my answer
Lucas
Jul 07, 2011 | Office Equipment & Supplies
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
Laserjet4 50 intervenire
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Apr 07, 2010 | HP LaserJet 4 plus Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | HP LaserJet 4 plus Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
183 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
