Question about Briggs Garden
Replaced stop switch and still won't shut off.
Briggs engine numbers 10H902, 0113, E1, 05091255
New stop switch won't move when lever is turned to stop position. Old stop switch tried to fall out when lever is turned to stop position. Engine will not shut off without pulling plug wire.
This engine is on an older Craftsman power washer.
  • 211 Answers
Hi
When lever is turned to stop position look under the levers" support and see if there is established a conection with the wire from the coil wich kills the running engine.Also check the conductivity of that wire.
best regards savumihai71
Posted on Feb 13, 2009
Where does the kill wire attach on briggs engine on maxim tiller
should come from the coil and go to the throttle control on the engine. when you move it to the stop position the arm will turn and hit the wire causing it to shut off,
Jun 25, 2017 | Briggs Garden
How do I lower a over raving 24hp over head valve briggs and Stratton motor
take the rod from the governor lever to carby off and see if you can move the governor lever freely or if it lees like it is not in the governor weights and cog groove
is the governor lever moving against the spring outside the crankcase
I suspect that you may not have put the lever end in the gear slot properly when reassembling the motor and the lever is not shutting the throttle plate as it should to stop over rpms
hopefully you did it right and it is the location on the lever on the shaft outside that requires repositioning
Dec 17, 2016 | Cars & Trucks
My zx7r, ive got no Ignition or Neutral light, I have replaced the ignitor unit,the clutch switch, the battery,the side stand switch,the junction box, the fuel pump and still no ignition? I took off my...
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.zxforums.com/forums/zx-7r-forum/50874-zx7r-won-t-start.html
my bike will not start zx7r
KAWASAKI NINJA ZX 7R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Apr 04, 2017 | kawasaki Ninja Zx7r Zx9r '94 To '04
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Missing a spring on briggs 5.75 HP engine. spring is for "engine stop lever" where the cable connects to on the engine. It is a small spring. What is the size and part number to that spring ? Thanks, Terry
Enter your engine model, type and code off the 5.75 engine on the Briggs website to get a detailed parts list and diagrams for that motor. (including OEM part numbers).
Aug 09, 2010 | Briggs & Stratton Garden
Engine shuts off when any drive gear is engauged
I hope you have fixed this by now. If you haven't It is possible that the ROS is malfunctioning. The tractor is equipped with a reverse operation system which allows the tractor to mow while backing up. It might be that the wiring in the switch or the shifter has become disconnected or broken.
For reference, the manual says this:
USING THE REVERSE OPERATION SYSTEM -
• Move motion control lever to neutral (N) position.
• With engine running, turn ignition key counterclockwise
to ROS "ON" position.
• Look down and behind before and while backing.
• Slowly move motion control lever to reverse (R) po si tion
to start movement.
• When use of the ROS is no longer needed, turn the
ignition key clockwise to engine "ON" position
Manual is available at: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007-PB175H42LT-405327-96017000401.pdf
Jun 06, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Replaced stop switch and it still won't shut off!
While attending college, I worked at a tool rental center and learned many tips and tricks from the mechanics. The problem that we heard the most from customers was that the machine would not start. Your your machine at least starts and runs fine, however will not shut down with the factory kill switch. Many times when replacing the mag. (spark coil) the kill wire would rub against the flywheel and break or over time the conductor wire will break inside the insulation. If you kill switch only has one wire, then all the kill switch does is short the mag to ground. Simple test is to remove spark plug, re-connect wire to plug, touch plug to engine and pull rope to observe spark, then short the tab on the magnito to ground, should be no spark. If you still have spark, coil is defective however good enough to run engine. Kill with choke or pull wire. If no spark with test, make new wire from tab of coil to kill switch or any switch that will short tab to ground. Good Luck
Jan 03, 2009 | Briggs Garden
Garden Logo
175 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
