Damage compact flash pins for card in unit DP-02CF. Can this be repaired and if so what does it normally run
  • ggwint Jan 04, 2009
    Any idea how much this repair can/should cost?
    Tascam DP-02CF compact flash pin input repair
    Thanks
    Damage to input pins for compact flash card needed for unit- Tascam DP-02CF. Any idea how much a repair can/should cost
    Scholar:
  • 97 Answers
If the pins are just bent and not missing, you may be able to bend them back into position.
Be sure to turn the unit off!! use a very sharp point or tiny flat screwdriver and pry them back into place. I have done this many times and surprisingly it has always worked. (if bent too badly the pins will break off... then its of course a repair job.
Good Luck!
FW
Posted on Jan 04, 2009
  • fryeggy
    fryeggy Jun 02, 2012
    I agree, I have rebent pins many times, there are two screws at the end of the dp-02cf, remove them to gain easier access to the pins. CAUTION: taking the unit apart in any way can be disastrous, thinks before you choose this method.
    Dan
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, I doubt if replacement "compact flash pins for card" fopr a Tascam DP-02CF would be readily available. However, you may want to consider:
  • defective/discarded memory card reader as "donor" for the slot;
  • similarly, defective/discarded digital cameras that uses the same physical sized memory card;
  • as to the tech/service, it wold not be a matter of fee, but finding one who would attend to the required repair as more of a challenge than a workload.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 04, 2009
    The parts/source/donor would /should be free. The service fee would be the ongoing rate within your area. Could be anywhere from 45~100USD.
  • 15,935 Answers
If it is just pin replacement, a repair tech should be able to do it for about $75USD
Posted on Jan 03, 2009
  • blueextc3221
    blueextc3221 Jan 03, 2009
    Don't spend more than $100 on it though! You can get a new one for $250 or a used one on eBay for $100 and then you'll have other spare parts as well.
    Genius:
  • 1,550 Answers
Yes it can be repaired .
  • SAM ANDERSON Jan 04, 2009
    The repair will cost around $100 .
Powers up but wont go past the tascam display screen
While the power is off, take out the CF card then turn the unit on.
Does it complain the card missing?
If so, it is the problem of the card related components.
Look inside the card socket, do you see any pin that is bent out of place?
If so, that's the source of problem.
If you are careful, you can open up the case and use a long nose pliers to straighten it (them) out.
If the socket is OK, try another CF card.
Jan 18, 2014 | Tascam Dp-02cf Digital 8-track Recorder
Tascam DP02CF not responding to anything what should i do nest please?
That's an 8-track recorder that records to a compact flash card. It is not a minidisc recorder.
Oct 01, 2012 | Tascam Dp-02cf Digital 8-track Recorder
DP-02CF Exports files to PC, but reads no file found when importing wav.
The answer is in the troubleshooting section of the manual:
http://tascam.com/content/downloads/products/241/E_DP-02&02CF_web.pdf
Page 53:
"Why can't my computer "see" the unit files"
Mar 01, 2011 | Tascam Dp-02cf Digital 8-track Recorder
My tascam dp-02cf wont turn on at alll.. the power plug is pluged in some 1 help asap
make sure that the main power source is OK which is AC line......
check the power cord,,
Aug 26, 2010 | Tascam Dp-02cf Digital 8-track Recorder
How do i fix the mount error, please power off.... on a tascam dp-02 when i turn it on?
The only solution I know of is: turning off the unit, then simultaneously pressing Track Edit, Cursor up, and power button until the unit asks "are you sure?" This will unfortunately erase the hard drive.
Jun 29, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Im looking for a manuel for my DP-02CF
http://www.tascam.com/products/dp-02;9,16,3580,19.html
Go here and under the picture of the unit is a free download of the manual. Good luck
Feb 08, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Can't erase?
Do you mean it will record new material but not erase the old, or that it will neither record or erase? Can you play old recordings?
Try removing and reinserting the flash card. If that doesn't fix it, try a new flash card. If that doesn't fix it, you need to take it to a qualified technician.
Nov 15, 2009 | Tascam Dp-02cf Digital 8-track Recorder
Problem importing files to Tascam DP02-cf
They don't mention in the manual that in addition to being 44.4khz, 16bit, mono, the wav file also has to be at a bit rate of 705kbps. Using Audacity (freeware) you can convert most any audio file into the necessary wav format for the DP-02cf to use.
Jan 24, 2009 | Tascam 2488 Portastudio Multitrack...
29 people viewed this question
 Grubhead
Grubhead
