Question about Jandy TELEDYNE LAARS BLOWER PRESSURE SWITCH
When I turn on the spa heater the pressure switch light flashes
As a result the heater is not working
    Top Expert:
  • Jandy Master
  • 7,206 Answers
If filters ok check pressure switch
Posted on Apr 29, 2016
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: service light is on say's to reffer to manual
Trouble shooting guide and Owners Manual
Posted on Mar 04, 2009
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
Posted on Aug 06, 2009
  • 246 Answers
SOURCE: my spa switch has a button that does not work
spa side switch need to be replace $175.00 free deliver
Posted on Sep 13, 2009
  • 990 Answers
SOURCE: I have an aqualink rs
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Posted on Mar 13, 2010
Testimonial: "The burner is lighting but won't stay on, more than a minute or so. I tend to think the problem is water flow, like you say. Thanks...DC"
The red light on heater won't turn on
This is an indication that the pressure switch is not working. When it completes the circuit thru the pressure switch it send power to the heater. It is the last fail-safe before power goes to the heater.
Bath & Spa Parts Online
Balboa 3 Amp Spa Heater Pressure Switch 2 0 PSI 30408
Aug 09, 2016 | Pool & Spa
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
Jun 22, 2014 | Hayward H Series Pool & Spa Heater...
Laars pool heater wont start.
check safety circuit starting with pressure switch if voltage on both sides ok if not check pressure switch if ok check copper tubing it gets clogged at header
Mar 27, 2013 | Jandy Laars Lt 400,000 Btu Heater
Jandy LX Pool Heater Pressure Switch Light Flashing Red
set back to where it was take off copper line unplug it should work
Jan 13, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pressure switch fault on jandy xl POOL HEATER
check to see if pressure switch has voltage both sides also check copper tube to see if plugged
Nov 12, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pressure light switch flashing when unit turned on
Check if there is an adjustable pressure switch on the delivery plumbing somewhere. It will be connected to the computer by a sensor wire.
Nov 08, 2009 | Jandy Laars Lt 250,000 Btu Heater
Hayward H400 heater problem
LO usually indicates low water pressure. Check the pressure in your filter. You may need to backwash. If the filter is to clogged then the water pressure in the heater is so low that it won't activate the pressure switch. While checking the pressure turn the pump off and then on to make sure the pressure gauge is actually working. Also check the pressure coming out of the inlets into the pool. You should be able to tell if you have sufficient water pressure.
Jan 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Jandy TELEDYNE LAARS BLOWER PRESSURE SWITCH Logo
41 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
