Question about Samsung TXE2546 25" TV
Tv turns on and off continually
When the tv is plugged in it will turn on then off repeatedly till the tv is unplugged.It doesn't matter what buttons are pressed on the remote.
The power supply is bad and must be replaced.
Depending on the TV and what your local repair shops charge, it might be cheaper to replace the TV. This same thing happened to me. I could replace the TV for just a little more than the cost of fixing it! I'm replacing the TV.
I'm sorry that I couldn't give you better news.
Posted on Jan 03, 2009
What is the remote code for panasonic TC-L32C3 for the time warner control?
turn tv on
on remote
1. hit tv
2. hold down setup till it blinks twice(tv button light)
3.then press 991 wait till it blinks (tv button light) channel up slowly until tv turns off
5. once it turns off hit setup again
6. press the tv then power button and then see if tv turns on if not then you just missed the code(repeat)
Aug 28, 2011 | Panasonic TCL32C3 TV
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Green light come on when you push on button.It goes off after 4sec.TV will not come on
Try this... unplug the TV. Press and hold the power button for 30 seconds, repeat. Plug it back in and attempt to turn it on.
Unfortunately, if this doesn't work, then the TV will need to be repaired or replaced.
Apr 22, 2011 | Televison & Video
I need to turn on&off the tv
1.) Unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
2.) Just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off.
Mar 03, 2011 | Insignia IS-LCDTV32 32 in. Television
When i turn on the runs for 5-10 min...then shuts off... this turn it back runs again for short time and turns off...repeats several times till it stays on...will stay on indefinitly till...
Hi Friend,
Please folliow the below steps one by one,try by resetting the TV
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card whether its has got any problem in the TV,
If you have any Clarification please feel free to contact us
Apr 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
No picture
Sounds like the bulb or lamp needs replaced.
Jul 08, 2009 | Televison & Video
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Televison & Video Logo
128 people viewed this question
Jerry Greenberg
Jerry Greenberg
