Question about Frigidaire FDE336RE Dryer
FDE336RES1 frigidaire electric dryer
Makes squeaky noises what part needs replaced and where do I find a repair manual that shows how to replace it.
  • Frigidaire Master
  • 8,220 Answers
FDE336RES1 frigidaire electric dryer - bb8c47e.jpgThat squeak can lead to a full blown drum failure into the heating element fiasco. Better pop the top and get thront off. Remove the drum and inspect the ball before it goes bye bye to China.Oh and while you are at it you may as well check the front glides
05b09de.jpgYou can FDE336RES1 frigidaire electric dryer - fc264f7.jpgbr />fc264f7.jpg
Posted on Jan 04, 2009
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
Noise in dryer Frigidaire model fde336res1 when running
Could be the drum bearings are worn. These are what the dryer drum turns on and when they wear out the drum and frame rub together (metal to metal). Also could be the belt idler which keps the belt tight around the drum. In either case the dryer would have to be internally accessed to determine failure.
Feb 17, 2010 | Dryers
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Frigidaire fde336res1
Unplug power immediately.
Check the fuses/circuit breaker at the back of the appliance.
You may need to have the heating element inside the machine tested, and eventually replaced, it had probably shorted out.
You can call a technician using the number listed on the owner manual.
You can get replacements here.
Oct 27, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
1,215 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
