Question about Radio Shack 15-2142 Remote Control
I have a radioshack 15-1993 how do i enter channels 100 and above the tv is a toshiba 27 inch about 5 years old i can only enter channels up to 99 is it possible to enter channels 100 and above how do you do it with the radioshack 15-1993
Thanks fixya
I found a button on the original remote. The numbers and letters were almost all warn off.But I found it and copied it to the radioshack remote.
Posted on Jan 04, 2009
I have a 27 inch sanyo tv with out the original remote,,,the tv is stuck in video mode how do i get to the channel settings so i can watch cable on it
You can try the Channel up/down but if that does not work it looks like a trip to your local radioshack or store with universals. Also there is another solution actually two..
Hook a good old VCR up to that baby and hook the cable to the VCR put the vcr on 3 and bingo or for your orginal factory remote.
Hope this helps please be considerate when you leaving you vota and feedback.
May 29, 2010 | Sanyo DS31520 31" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Ihave an old Toshiba tv and a Systemlink 3 romote. I lost the code book, please send me the codes. Thanks
The codes for Toshiba are: 049, 071, 072, 089, 105, 109, 117, 118, 160, 162.
1.Find the three digit code(s) for your TV set.
2. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
Good luck and I hope this helps. Thanks for using fixya.
Jan 03, 2010 | Toshiba 27A33 27" TV
Current value of a jvc 32 inch color tv 8 years old
The street value would be 100-150 dollars. If TV is a cheap model or abused or very used, you should pay less.
Consider a Sony or a Toshiba in tube style since all are cheap now.
Sep 27, 2009 | JVC AV-27D302 27" TV
I have a 32A14 Toshiba TV. At full screen, the
you have to take in affect on how old is the tv if you have had it a few years then the screen is going out and will only be a matter of time before it goes all the way out and you will be buying a new one if it not old and its one of the newer flat panels then its the signal that the tv is receiving if its hooked to a digital antena then you only get max of 720 from it on certain channels no matter if the channel or channels are showing hd with out a hd source your tv will not show better then that i have a 42 inch hd flat panel and use a antena and the best i get from my hd broadcast channels certain times will i get true hd like when the news is showing or when one of the series that was filmed in hd is on other then that i only get a 720 picture instead of a 1080 most commercals are not film in 1080 but in 720 max and i dont know why makes no since
Aug 28, 2009 | Toshiba Televison & Video
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Press menu key
highlight channel scan memory
press vol+ to highlight number entry area
enter channel you want to enter eg. C16
or if above 100 press and hold the 1 key until C1--pops up
change deleted to added by pressing vol+
Nov 15, 2007 | Sanyo DS27910 27" TV
Audio, but No video when connecting DVD player to TV
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Apr 15, 2007 | Toshiba CZ27T31 27" TV
Radio Shack 15-2142 Remote Control Logo
200 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
