Question about HP OfficeJet 7310 All-In-One InkJet Printer
Broken scanner glass on HP All-in-one 7310 Printer
Does HP have a replacement part or do I just take measurements and see a glass doctor?
    Genius:
  • 2,120 Answers
See the doctor, not available.
Posted on Jan 03, 2009
When scanning or copying from either the ADF or the flatbed, my 7310 puts a black line all the way down the right side of the page exactly 1 1/2 inches from the right edge. I have cleaned the glass (and...
You can check the white guide bar that sits above the glass, any marks on there will leave a streak because it is the white reference for the scanner. after that you will probably need a new scan assembly because sometimes single elements will burn out.
Aug 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Every time I turn on my officejet 7310 printer a warning comes up saying scanner failure. I cannot do anything with it. I uninstalled it & reinstalled it but with no luck getting it to work> ...
Sometimes you can clean the scanner optics and get a little more life from it, but it involves taking the glass off the top and cleaning the scan unit mirrors and lenses. When that doesn't work you need to locate a new scan assembly, last check, around $150.00
HP OfficeJet 7310 - scanner stopped working
Do these tests. Try coping form the glass and ADF tray. If it works from the glass and not the ADF tray then you have a bad scanner motor assembly.
Michael
Perfect Printer Parts
Jun 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7310 - Scanner Failure - Can't Remove ADF
These printers are notorious for having bad scanners. The fix will not last long. Replace the printer.
Mar 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 7310 All-In-One giving a dark line one scans and copies
I had the same problem but figured it out. Both sections of the top of the printer open and under the left side there is a separate "scanner window" that you can't see unless you open that side. lift your regular scan tray and then pull the left side up (it opens out to the left) and then left the piece that is under it. You should be able to see the thin scanner window. You can clean it with rubbing alcohol or even windex.
Feb 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Broken Scanner glass on HP All-in-one Officejet 7310. Does HP carry replacement or do I see the glass doctor?
Try this site for a Glass Replacement Kit for your scanner.
http://www.everprint.com/online/SIMDetail.asp?partno=Q6500-67904
Jan 03, 2009 | Office Equipment & Supplies
The glass for the scanner broke, i need another one
Eek, that's a tough call.
I think the cheapest would be to take the measurements and have a local glass company cut it to size.
I've never seen a manufacturer offer replacement glass tops for their scanners. The model isn't listed, but it's probably going to be cheaper to either buy a new one or buy a broken one off ebay and take the glass out of it to use in yours.
Dec 06, 2008 | HP Officejet 5510 All-In-One Thermal...
HP 7310 Deskjet all in 1 printer - scanner problem
try to claen the glass see is there any mark of dust or nay lines of colour just clean it and see
Oct 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Can not fas from officejet
Are you having a problem with the scanner portion of the machine? When you place the original to scan into the ADF or on the glass, do you get a scanner error message? These machines have a history of scanner motors going bad.
Jul 13, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7310 All-in-One Scanner problem
If the HP service cant help, then try to get a exchange, the machine usually have a warranty.
Jul 10, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
192 people viewed this question
Ben Johnson
