Question about Health & Beauty
1036 kitchen scales displaying un5t
Will not work nearly new showing un5t
kristineluci
  • 30 Answers
SOURCE: Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Posted on Aug 21, 2009
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Posted on Oct 05, 2009
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
SOURCE: E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Posted on Dec 29, 2009
SOURCE: My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
Posted on Jun 21, 2010
  • 906 Answers
SOURCE: My Terallion electronic kitchen scale shows an out2 error
good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 04, 2010
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
What is error code 2402
Error code 2402 is displayed, means unit is wet, time to purchase new scale. Cannot be fixed sorry.
May 25, 2014 | Terraillon 5 Kg Maya Scale
Polder kitchen scales light flickers after batteries changed
This was suggest by TWC42 on Amazon. I tried it and it worked. Had the same issue with mine. Here's a fix that might work. Set batteries aside. Remove the 6 screws from the back with a small phillips. Lift off the back. Remove the 5 smaller screws holding the display in place. Insert the three batteries. If the display now shows a number without flickering, do not remove batteries. Carefully replace display, reinsert five screws. Place back on, reinsert 6 screws. Turn over, see if off/on works. Mine did!
Feb 28, 2012 | Health & Beauty
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
May 14, 2010 | Salter 2001 electronic kitchen scale
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Aug 21, 2009 | Salter 2001 electronic kitchen scale
Mar 31, 2009 | Salter 2001 electronic kitchen scale
Health & Beauty Logo
201 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
