Question about InFocus IN2124 New
Infocus in2124 won't power up - InFocus IN2124 New
2 Suggested Answers
tech4allmen
  • 666 Answers
SOURCE: My Infocus 5700 won't power
We can fix this. I believe you are handy enough to fix the power supply of this masterpiece.
I had 100% the same problem and finally figured it out. The problem is with one of the capacitors, and after lots of trial and error, and asking for advice, here it is: The capacitor is "C16" - a small blue electrolytic - 100uf 16v. It is in the center of the power supply board partially hidden by a black heat sink and the large silver chunk of metal.
Swapped for a 25v 100uf I had lying around and she works like a charm now.
Here's how it looked like on mine:
images?q=tbn:and9gcte64-3vvp7h6vtswd6pxijyyxdvcyifqgbtov0jpszkmueqklupg
Posted on Aug 24, 2011
Infocus screenplay 5700 I've had this product for
Hi!
Just had the same problem and I want to sincerely thanks rey francis basa !
I went down and changed C16 as you said. Exactly where you said.
Works perfectly now!
Jan 05, 2013 | Office Equipment & Supplies
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
Blinking red light. projector won't turn on
The lamp life may have exceeded its safe limit, check your manual as you may have to press a specific button on the unit/remote for a length of time to reset it.
Good luck
Aug 03, 2011 | InFocus ScreenPlay 5700 Multimedia...
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus lp530
I called InFocus and was walked through several steps to determine if it was a bad cable or an internal problem. My InFocus unit would power up and stay powered up with no problem until I connected it to the computer using the analog computer cable (blue connectors). They had me try it with a different computer and then with the S-Video cable. Each time the InFocus unit powered down within seconds of connecting to the computer. The problem is internal. The unit had to be sent to InFocus for repair ($180). If the unit works with the S-Video cable then your problem is a bad cable.
Jan 08, 2008 | InFocus LP70+ Multimedia Projector
InFocus IN2124 New Logo
141 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
