Question about Gateway M465-E Notebook
Gateway laptop m465e power supply problem
My computer seems to have a power problem. I have 2 adaptors that I know work, but i can just be working on my computer and it will lose power. The battery isn't getting charged either so I can't even work on off the battery. I would by a new battery, but if the power supply won't charge it I don't see a reason to spend the money. The rest of the computer is still in great shape and would love to keep it, but need to find out how to fix this connection otherwise the computer will be of no use.
  • pettycd May 18, 2009
    The battery went dead and won't charge.  Shouldn't the computer work since it's plugged in even if the battery won't charge?
    Problem Solver:
  • 11 Answers
Hi, My name is Michael Fuller, I'm the owner of Computer Eworld. I have this laptop and mine had the same problem, 2 things are wrong, your bios needs to be updated and your system needs to be updated. If you want, I can fix this problem, it will cost you $35 for the labor, and of course the shipping charges. You can put your request in on the company website or you can call me directly, my number is 662-549-2362. www.computereworld.com well good luck and have a happy new year!
Posted on Jan 11, 2009
M465-e has flashing blue light wont startup
Try removing the battery and disconnecting the power for a minute or so. Then re-install the battery and power cord and try booting it up again. If that doesn't work I'm afraid it's probably an issue with the motherboard.
If in the unfortunate event the motherboard needs to be replaced, here are the instructions:
http://www.ehow.com/how_7498700_remove-motherboard-gateway-m465e-laptop.html
Looks like boards range between $100 - $200
If it's not something you want to tackle yourself, expect labor to be about $100. Consider the age of the laptop and the cost of about $200-$300...some newer laptops can be had for that amount. (Especially with Black Friday sales going on.) Check microcenter.com
Nov 24, 2012 | Gateway M465-E Notebook
Screen wont come on
For that Laptop problem. try this solution first remove battery backup of your laptop and then connect power supply adaptor then power on, if not yet screen display. try also cleaning laptop memory module slot at back of laptop.
Check-up also power supply adaptor for 100% working good. also laptop hole connector for power supply.
Just let me know if not yet working your PC laptop.
Oct 14, 2011 | IBM ThinkPad T43 Notebook
Is there in built web in my laptop M465E gateway. if not then tell me how to attach my logitech web cam with it.
There is a WLAN, a wireless internet connection card for this computer and connecting your webcam should be as easy as plugging it into your USB port and using the disk it came with to activate it. If the picture is correct on this question, you need an adapter from you local computer store. The adapter will likely be about 5 to 20 dollars, and this will allow you to plug it into a USB port after you attach the adapter.
May 23, 2011 | Gateway M465E Laptop Charger...
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
I JUST GOT A GATEWAY M465E NOTEBOOK ON 07' ,IT WONT POWER ON!!! I THOUGHT IT WAS MY CHARGER SO I BOUGHT A NEW 1 FOR MY EXACT MODEL & IT STILL WONT POWER ON! IM TRYING TO SEND IT BACK FOR REPAIR OR A...
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 22, 2009 | Gateway M465-E Notebook
Cooling fan doesn't seem to be working
If you have a volt meter you can see if the computer is putting out power to the fan, also you should
be able to test the fan on an external power supply, if you dont know the fans voltage start off at 5vdc
, most fans are 5 to 12 volts. Hope this helps
Dec 22, 2008 | Gateway MX3228 Notebook
Laptop does not power up or turn on anymore!
You seem to be in deep trouble..
It sure seems to be a motherboard issue. I will advise you to buy a new MBD. And to your relief, the data on harddrives will be "nil" affected by the motherboard change.
There might be an easier and cheap solution to the problem, but the area to be audited to find the solution is large with no guarentee that we will find a viable solution. Motherboard replacement will be an instant solution..
If you own a dell laptop, but a complete cover warranty that will include a free motherboard replacement and warranty for 1 more year..
Dec 18, 2008 | Gateway MT6707 Notebook PC
Connecting Gateway Keyboard to Dell Laptop with PS/2>USB Adaptor
Does the entire keyboard function with the multi-adapter? I am having the same problem, and i just bought a single ps/2 to usb adapter. If it works, let me know. THanks!
Oct 15, 2007 | Gateway 2520915 Keyboard
Gateway M465-E Notebook Logo
585 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
