Question about Refrigerators
My ice maker keeps clogging up to where it will not dispense ice out i dont know the correct setting that freezer should b on please tell me its a subra
2 Suggested Answers
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
My ice maker keeps on getting clogged up and won't dump ice!!! Is there something I can do to correct this?
The most common cause for this problem is setting the freezer temperature to low. If digital, set to5 degrees, if rotating thermostat, set mid scale (example 0 to 7, set to 5)
Setting temperature to low causes the dispensing flap to frost up to not close properly after dispensing. If it does not close even more frost forms and ice starts slumping together causing ice to jam.
Hope this helps!
Apr 18, 2016 | Refrigerators
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
The water solinoid is not sending water to my ice tray
The 2 "problems" are most likely only 1 problem. The door frame has a heater that keeps water from condensing on the frame tween the freezer and refrigerator sections. It should be warm but not so warm that it is uncomfortable to keep your hand on it.
Now your saying verry little ice at best? Do you notice ice in the bin that the refrigerator has made? You can try switching the wires on the water solonid on the back of the fridge then push in the button on the water delivery switch (like filling a glass) if the valve is working the water should flow on into the ice maker and you can feel it or see it being in the ice maker. then you know the problem is, or is not in the water valve. If you leave it connected this way for an extended time like 4 to 6 hours you should notice a mess comming out of the water delivery spout in the front. This will be because the ice maker is comming around and asking for water to come into the ice maker. However because you have switched the wires on the valve it comes out the door. If you dont get any water out the door the Ice maker isthe most likely suspect but it could also be the wiring going to the valve.
If this helps you find the next step in solving your trouble please rate me has high as you can and thank you for using fixya.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
