Question about Refrigerators
Hi, I have a samsung refrigerator m#RF268ABWP The ice door for the upper ice maker is opening and closing and will not stop. Do you have a recommendation as to which control would be most likley the c
The flapper for ice dispensing on the left refrigerator door
Rotu
  • 175 Answers
SOURCE: No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Posted on Dec 17, 2006
peyton32034
  • 410 Answers
SOURCE: Kitchenaid KSCS25 Refrigerator Ice Maker Inop
you should not be able to push the stripper at all so that tells me that the gear on the icemaker module is bad. get part number 8201515 and you should be fixed up.
Posted on Jan 07, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
  • 552 Answers
SOURCE: My Maytag MF12568AES Refrierator control panel
this is a very common issue the control board on the back of the unit is bad, you will need to replace it to fix this issue, let me know if you need more help,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
I have Samsung refrigerator RFG298 series the ice maker stopped working and sounds like a dog barking when it's running any ideas what it could be ?
Possibly the gear drive faulty in the ice maker, or it could be the dispensing chute has ice blocking it from closing properly. Completely empty the ice tray and make sure there is no ice anywhere in the tray, guides or ejection chute to the front door. On some, there is a little button under the icemaker for testing and forcing an ice maker operation. Press it and see if the ice tray rotates and reloads with water.
Nov 20, 2016 | Samsung RFG298HDWP French Door...
Samsung Refrigerator water dispenser does not work? Ice maker works
The electrically operated valve that opens when you attempt to get water is probably bad. This unit may have one unit with two valves. One each for the ice maker and water dispenser. This valve unit will be in the back of the refrigerator and have a copper or plastic supply line from your house. This line will be "live" so be sure and find and close the valve attached to your house's water supply.
Mar 02, 2015 | Samsung Refrigerators
The swing arm gets stuck behing the ice bucket and the drawyer won't open
Swing arm alignment can be restored by resetting the ice maker. There is a reset on the bottom, near the front of the ice maker. HOLD it down through a complete cycle, about 8 seconds, then wait for the two-tone chime to indicate the reset is complete. Failing that, a new ice maker may be needed, the old one may need thawing or there is debris under the bin or arm stopping the cycle. I have actually tore this thing off by opening the freezer at the the exact moment it was cycling too, arrrrgh.
Jul 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker stopped working
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Mar 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Noise on the ice maker
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Jan 05, 2009 | Samsung RS2630WW Side by Side Refrigerator
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
