Question about Stihl Garden
Stihl 029 super - no spark
029 super no spark
  • 4088 Answers
SOURCE: Got a Stihl 029 super, fresh gas ,vapor coming
Fuel may be leaking past the carburetor fuel flow needle and seat due to dirt negating the control action of those two components. A tear-down and cleaning of the carburetor would likely help. Check the condition of the diaphragms and valves as well. There is a complete description of 2-stroke carburetor action (Walbro brand) at:
http://www.drystacked.com. It's a 12 page PDF. Hope this helps!
Posted on Dec 31, 2009
dontbother10
  • 2220 Answers
SOURCE: hole in oil tank need to replace need help
New Stihl parts and IPLs are proprietary. The only source of parts is eBay or Stihl.
Lou
Posted on Feb 09, 2010
dontbother10
  • 2220 Answers
SOURCE: no spark what are the ohms specs on this coil this
Answered in clarification.
Posted on Mar 06, 2010
  • 67 Answers
SOURCE: stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Posted on Apr 08, 2010
barterjoe
  • 338 Answers
SOURCE: I have a stihl 029
If the clutch drum was not set on the oil gear spring properly the housing can wear out and leak oil. I recommend removing the clutch and inspect the housing.
See a local dealer like www.arcolawn.com for parts.
Good luck
Posted on Mar 28, 2011
My 029 stihl wont stay running and spits gas out of air inlet
Check your muffler's spark screen to make sure it's not restricted. While you have it off inspect the piston for scoring.
Jun 03, 2017 | Stihl Garden
Broken wire on stihl 029 saw.
one of the wires will go to a stop switch as that will be the method of shorting out the coil to stop the engine
I have an stihl 029 super chain saw that the spark plug won't stay in it. What parts do I need to fix it?
If the threads are crossed, stripped or loose, you need to take it to an engineering place and have a 'helicoil insert' fitted, this is a new steel insert that is tapped and threaded into the head after the hole has been enlarged a little.
helicoil insert Google Search
Dec 12, 2016 | Stihl Garden
Engin parts for 029 super stihl chain saw
perhaps a STIHL dealer can assist you .
Dec 09, 2016 | Cars & Trucks
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
029 stihl wont start
Disconnect the stop switch to rule out a problem here, if there is still no spark with the plug out and earthed against the cylinder, then it sounds like a replacment ignition unit is required
Nov 25, 2012 | Stihl Garden
Stihl 029 super oiler is not working
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
60 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
