Question about GE Monogram ZVB36 36" Downdraft Kitchen Hood
Is there an internal fuse in the GE Vent Hood ZVC36L1SS?
2 Suggested Answers
SOURCE: Where can I find the internal fuse on the GE
There are (2) inline 5A - 125V fuses under the top fan/duct cover. They are located on the left side (as facing the unit) in a plastic junction box. Four Phillips head screws hold the cover on.
Posted on Jan 14, 2011
Unit has no power. Circuit breaker OK. Is there a fuse somewhere in the hood?
Very likely the power supply unit is faulty or the controller itself. The parts list shows no fuse internally. The power is directly going to the control board (item 3). Make sure you turn power to the rangehood off at circuit breaker before working on it.
JENN AIR Vent Hood Hood components complete Parts Model JXT5830ADS
Sep 06, 2014 | Jenn-Air JXT5830AD Kitchen Hood
Ge hood insert zvc36l1ss fan comes on by itself. When not cooking?
The switch is bad. That makes it a possible fire or electrical hazard.
You should replace the switch immediately, or at least turn off the breaker that supplies power to the unit.
Don't let a broken $20 part be responsible for burning your home to the ground, fix it!
Parts for this hood are at http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Range-hood-Parts/Model-ZVC36L1SS/0432/0122400
This shows you how to open it up and replace the parts: http://www.searspartsdirect.com/partsdirect/user-manuals/9235/ZVC36L1SS-GE-Parts-RANGE+HOOD-manual?pathRender=fromManualTabPage
Jul 26, 2014 | Microwave Ovens
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
My GE Microwave fan will not shut off it is brand new just installed one hour ago. Not used yet How can I get the internal fan to shut off
That's usually caused by a shorted hood TCO (thermostat or thermal cutout) or if the cooktop lights were removed or installed while power was applied, a surge could have damaged the control board.
I would check the owner's manual, and look carefully at the section which describes when and how the hood vent exhaust fan comes on.
If it seems to be defective, I would get a replacement oven from the dealer.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | GE Microwave Ovens
Whirlpool MH2155XPS-0 does not work. Outlet and breaker are fine. Is there an internal fuse?
Yea there is a fuse behind the control panel. Remove vent loover then remove srew that holds control panel it will lift up & out the fuse will there somewhere. good luck
Dec 18, 2010 | GE JVM1850 1000 Watts Microwave Oven
Where can I find the internal fuse on the GE Monogram Hood model ZV950SDSS?
Dec 30, 2009 | GE ZV950SDSS Kitchen Hood
GE DVLR223 dryer wont start....breaker is not tripped
check all the connections on the back of the dryer, if a few screws are loose, that could be the problem.....now the other thing....it might need a new motor. Unplug it before checking it out!!
Clean out your vent hose and the outside of the Vent to prevent fires.
Jul 31, 2009 | GE DVLR223 Dryers
Ge monogram hood has power but not working
I have the same problem, only worse. The fuse is in the stack above the motor. You have to remove the vent decorative cover (that stainless tube that goes to the ceiling) and the fuse is in the low voltage circuit close to or inside the gray box that looks like a transformer (on the left). Mine blew out and I replaced the fuse, which lasted for about two months. I replaced it again and it lasted two days. Then, I replaced the triac with an NTE5679 (over on the right) (replaces ECG5679) about two years ago, and the fuse lasted until today. I do not know what to do now. We did not touch a switch just before the fuse blew. The fan was not running, but the lights were on. I think I will try a slightly larger fuse, but first I may look at replacing the fuse with a breaker that I can install behind the filters, instead of removing the stack cover every time the circuit goes out. Good Luck to you.
Ravenhaven
Apr 12, 2009 | GE ZV750SY Kitchen Hood
Microwave dead even though power works
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Dec 04, 2008 | Microwave Ovens
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
