Question about Compaq Presario 700 470024-192 Notebook
Unable to get it to boot to CD/DVD drive
Does not want to boot, is set to boot to this device but will not.
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    Is it set to boot from DVD in your BIOS?
    /Teis
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
How to reset acer to manufact setting
Use the Acer recovery CD you need to boot up with the CD.
Go into the BIOS setting and scroll through the settings until you come to Boot order. Then move the CD/DVD drive up as the first boot device and the hard disk as the 2nd boot device.
When you boot up the Acer with the recovery CD in the CD/DVD drive then it will boot up with the Recovery CD and follow the instructions.
Jun 17, 2012 | Acer Aspire One D250 Netbook
When the laptop is starting up, the screen goes black and this message comes up: "Check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any...
We Wish You a Happy New year.
Step 1: This might be because of external devices or non-bootable CD or DVD in the CD/DVD drive. Remove all the external devices (including pen drive/flash drive/CD or DVD disc) connected to your computer and then check for the issue.
Step 2: It might also happen if system is unable to find any bootable device.
Try restoring default setting in BIOS (Basic Input/Output System) and check. Also please check for the boot priority. For this you have you to contact the system manufacturer.
Step 3:Clickthe below link and follow the steps.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=PXE-M0F:+Exiting+Intel+PXE+ROM&x=5&y=4
BIOS DISCLAIMER
Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
Hope this helps you. Cheers!!!
Jan 03, 2011 | Toshiba Satellite C650DST2N02 Laptop
How can i change first boot device cd rom to dvd rom
To change your boot device you must change the setting in you BIOS.
To do this restart your computer and press delete repeatedly.
When you are in the BIOS search for Boot Priority within the different tabs.
To set you DVD Drive as the boot device make sure it replaces the CD Drive.
Set the DVD Drive as the first priority and your Hard drive as the second boot priority.
Save the settings and exit.
This will enable you to boot from your DVD Drive if a bootable disc is present in the drive.
Let me know if this solution was helpful!
Regards
Nov 30, 2010 | Gigabyte GA-8ST800 Motherboard
Dvd drive not detect in IDE secondary
Go to the BIOS settings and in the main menu and set the first boot device as cd rom. Then reboot ........
Apr 24, 2010 | Computers & Internet
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
Unable to boot the windows xp cd
check your boot settings in the comp bios/cmos set-up, you should the boot order of the devices in your system, make cd/dvd romyour 1st boot device then make the hard drive your 2nd boot device then so on, save the changes you had made and reboot insert your windows installation disc then from there it will boot to the xp cd
Dec 07, 2009 | Dell Dimension 4600C PC Desktop
UNABLE TO BOOT FROM WINDOWS XP
First Make sure your cd/dvd rom detected in bios.
For that First open cpu cabinet refix power cable and ide cable to harddisk.
Then check your bootable recovery disk and cd/dvd rom working fine.
When you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set first boot device as your cd/dvd rom then save settings and exit.
Then it boot with disk .
If still not boot then there may be some issue with cd/dvd rom or bootable disk.
Let me know if you need more assistance.
Thanks.
Oct 13, 2009 | Computers & Internet
Usb cd boot
you need to set the boot device priority in the BIOS in such a way that the computer will take an external CD/DVD-drive as first boot device. to do this, you need to enable USB legacy support first, save and exit from the BIOS settings and then return to the BIOS to set the USB-CD/DVD-drive as primary boot device.
Jun 22, 2009 | Dell PowerEdge 2600 Server
When I boot from a boot disk I am unable to change to another drive tells me each drivce is invalid. Also unable to boot from cd. I have 1) a drive (uncheck or check to turn off or on) 2)hard drive same...
Check the cabling between the drives. Make sure the BIOS sees your drives. Try swapping the ribbon cables between the drives and the motherboard. If you have to, disconnect each device and test them one at a time. This process should isolate the problem device. Make sure that the drives' jumper settings are correct, too (per cable if two devices, one master and one slave, or both devices set to cable select).
Mar 11, 2009 | Dell Dimension 4500 PC Desktop
Compaq Presario 700 470024-192 Notebook Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
