Question about Panasonic KX-FPG376 Plain Paper Thermal transfer Fax
Cannot go back to default greeting message
I cannot get back to the default greeting message on my Panasonic KX-FPG376 machine. We recorded a personal message that got messed up and we just want to go back to the factory default message.
I even reset the machine (Code#80) with no results. The manual doesn't seem to help.
Thanks,
Press Erase twice, display should read "2. TAD GREETING". Press Start twice, you should hear two beeps and the greeting should be erased.
Posted on Oct 19, 2011
    Problem Solver:
  • 13 Answers
According to the Operating Instructions for this machine, chapter 7.1.1. says that by erasing your recorded message, the machine should be set to play the pre-recorded greeting message again. And I guess you can then go on and try to record a new message, hopefully it will be more successful this time. I don't have this machine myself, but I wish you good luck!
Posted on Jan 03, 2009
The answering machine out going message is a pre recorded message with a British lady's voice. We have our company message recorded as per manual, what are we doing wrong?
Marianne
If a personal greeting has not been stored, the pre-recorded greeting is played.
unfortunately the user manual does not say how to store a greeting but I am assuming you have to press 2 to accept the new recorded greeting and hopefully it will store the recording as it is not really explained in the user manual on the process on how to store a greeting.
ftp://ftp.panasonic.com/telephone/om/kx-tg4500_en_om.pdf
page 60
Are you pressing two (2) to accept the greeting after you record it ?
Mar 17, 2016 | Panasonic KX-TG4500 Phone
I would like to change the answering machine message
Record a Personal Greeting
Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
Press 8 (RecNewGreeting).
Wait for the system to say "Record greeting," then begin speaking.
When you're finished, press 8 to stop recording. The system plays back your new greeting.
To keep this greeting, press End. To re-record it, go back to step 2.
Aug 21, 2013 | Panasonic KX-TGA101S Cordless Handset
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Nov 21, 2008 | Panasonic KX-TG9331T Cordless Phone
Greeting was somehow erased
Hi Sherrie, I am sorry to hear about your husband, I will do what I can to help. I am fairly confident on that model that if you push the greeting button, then delete it will erase the message for good. Also, if the memory power failed, then it would reset to the default greeting and erase all messages and greetings. However, if the unit has options for multiple greetings (ie. default greeting, greeting 1, greeting 2, etc., then perhaps the default greeting may have been selected, while your husbands greeting is still there but is recorded under say greeting number 1. If that is the case, you can select it to play his greeting instead of the default greeting to have it play. I would find out for you but my computer is having trouble opening the manual on the Panasonic site, so here is the link. Look under "greetings" in the index. Hope I helped. Thanks, CG http://service.us.panasonic.com/OPERMANPDF/KXTM150B.PDF
Dec 18, 2007 | Panasonic KX-TM150B Digital Answering...
Panasonic KX-FPG376 Plain Paper Thermal transfer Fax Logo
221 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
