I'm looking manual for ceramic heater model # is ch110
I would also like to get a manual for this heater model ch110 Thanks Rich
    New Friend:
Is your heater broken? I'm sure I can tell you how I would fix it.
Posted on Apr 11, 2015
2 Suggested Answers
  • 4736 Answers
SOURCE: I purchased a DeLonghi ceramic
Deanna, apparently the model heater your purchased may have been discontinued. However, Delongi may still support it. Contact their Customer Support Dept 800-322-3848, as they can provide you with the Owners Manual.
Hope this helped you. Please let me know. Thanks
Posted on May 12, 2011
Honeywell portable heater HCE322V manual
Honeywell has the manual for the HCE322V ceramic tower heater on the product page: http://www.honeywellstore.com/store/products/digital-ceramic-tower-heater-hce322v.htm . Click on the Manuals tab. The direct link to the manual is http://www.honeywellstore.com/store/images/pdf/HCE311-HCE322-HCE323-honeywell-heater-manual.pdf .
I hope this helps. Note: the manual covers a few different models. You should ignore any section about the HCE323; that model has a remote and a few other extras.
Jan 08, 2017 | Honeywell Heating & Cooling
Ceramic heater only blow cool air
Unplug the unit and look on the bottom or the back, there may be a circuit breaker reset switch.
If not, it's probably a fuse that's blown inside the unit and isn't made to be replaced.
Sep 24, 2012 | Lasko 6405 Designer Series Osc. Ceramic...
I have a Lasko model 5420 compact ceramic heater and would like to clean the interior . There are 4 screws that attach the back, 3 are philips head but the fourth is a head design I don't recogniz
Requires a special security screwdriver. I modified a slim old screwdriver by filing a small V in the middle of the blade. You can also buy 1/4" driver bits at Harbor Freight, etc.
Jan 07, 2012 | Lasko Heating & Cooling
I have a heater that has a fake flame effect. The heater works but the flame effect doesn't. I figure it needs a new bulb but can't get figure out how to get to it. HPDBL2D2 is the number on the...
Sorry, but the HPDBL2D2, apparently is not the Model Number. What is really needed is the Brand/Manufacturer and Model Number. Also, is it an Electric Fireplace or an Electric, look a like Wood Stove? Get me that, and I can probably help you.
Thanks, Rich
Jun 20, 2011 | Heating & Cooling
We just put a new bottle gas in our heater but the flame is dancing now and not going in to the plates behind. The pin is also getting orange from the heat. Whats wrong.
From what you have described, it sounds like the venturi valve of the burner is dirty and/or clogged. In other words, it's not getting enough air to gas mixture to burn as it should.
Since yours is an Infrared Portable LP Gas Heater, it's not difficult to dismantle the front of the heater's cabinet to remove the ceramic plaques and gain access to the burner & all it's inner workings. Before you even attempt this, TURN THE HEATER OFF AND ALLOW IT TO COMPLETELY COOL.
There should be 6 to 8 sheet metal screws around all sides of the heater cabinet that will need to be removed. After that, carefully remove the ceramic plaques and set them well off to the side. With a vacuum cleaner that has a hose and brush attachment, thoroughly vacuum all of the interior of the heater, as well as the burner(s). Look for the open end of the burner, that has a gas line/tube running into it. That's the Venturi Valve. You should see some small slotted openings (on some models, it looks similar to fan blades). If you have a crevice tool for your vacuum, use that to thoroughly vacuum the Venturi Valve.
While you're cleaning, use a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the pilot opening and the Oxygen Depletion Sensor (ODS). It will be a small hose in the side of the pilot a little over half way down from the pilot tip. Place the straw nozzle just barely into the hole and give it a quick blast of air.
Once you have completed all of the above, reassemble the heater in reverse order of how you took it apart. Make sure the ceramic plaques are positioned and aligned properly and all screws are reinstalled in the heater's cabinet. Light the pilot as you normally do and turn the control valve to the ON Position. Do the burner flames now appear as they should? If so, you solved the problem. Make that heater cleaning, part of your annual routine maintenance on the heater. Usually, in the Fall before you fire it up for the heating season.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 15, 2011 | Heating & Cooling
I purchased a DeLonghi ceramic heater DCH2570E but there wasn't any box or instructional manual. Do you have anything that I could instructions for this model that I could download. Thank you.
May 12, 2011 | DeLonghi Heating & Cooling
I lost my owners manual & would like to know how to turn & operate my lasko ceramic heater. Thank you in advance. Roy Reyes
Follow this link:
http://www.laskoproducts.com/heaters/heaters.html
and put in your model of heater. Once on your models page, the link to the manual is near the bottom of the page, a red link.
Mar 15, 2011 | Lasko Ceramic Heater
Noisy B&D Ceramic Heater
unit uses a sealed "muffin" fan.  you could check out grainger supply for a replacement fan.
Feb 22, 2007 | Black & Decker BDCH100 Ceramic Compact...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
