Question about Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game
Mounting fold a hoop - Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game
2 Suggested Answers
SOURCE: replacment 7" basketballs
http://www.amazon.com/Voit-Voit%C2%AE-Super-Mini-Basketball-EA/dp/B001285TW8
One reviewer even specifically notes that he bought them for your same game.
Posted on Jan 05, 2009
Embroidery hoop
No there should not be a lot of play.
Jan 31, 2014 | Janome Memorycraft 9700 Computerized...
Tip
Door Latch Replacement (Fdl Error
This advice is for replacing the door latch on the Kenmore Elite or Whirlpool Duet FRONT LOADER washing machines.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
on Mar 07, 2010 | Washing Machines
What does "dl" and "f" mean
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2010 | Kenmore Elite 45986 Front Load Washer
The display show FDL.
1. Unplug washer.
Sep 19, 2010 | Kenmore Washing Machines
F dl error
1. Unplug washer.
Sep 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pannel reads dl-f modle # 110 42926-203
1. Unplug washer.
Sep 16, 2010 | Kenmore Elite 45986 Front Load Washer
Flashes dl f
1. Unplug washer.
Sep 12, 2010 | Kenmore Elite 45986 Front Load Washer
What causes f/dl error code
1. Unplug washer.
Sep 21, 2009 | Kenmore Elite 45986 Front Load Washer
What does F dl mean?
1. Unplug washer.
Jun 28, 2009 | Kenmore Elite 45986 Front Load Washer
Replacment 7" basketballs
Jan 04, 2009 | Park and Sun Sports PS-FAH Fold-A-Hoop...
Park and Sun Sports PS-FAH Fold-A-Hoop Basketball Game Logo
Top Park and Sun Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Park and Sun Toy Expert? Answer questions, earn points and help others
