Question about Husqvarna Sewing Machines
Need to move needle to the right on viking rose
Want to use the 1/4 inch foot but cannot figure out how to move the needle to the right in order to have the correct width...manual leaves much to be desired
dupina
  • 110 Answers
SOURCE: Husqvarna Viking #1 use same foot pedal as the #1+ ???
Yes it will work, you can go ahead and purchase it.
Posted on Jan 22, 2008
SOURCE: buying a used Husqvarna Rose or what other recommendation?
I owned a Rose sewing machine and I recently upgraded to a Designer 1. I absolutely love this machine!! It's very easy to learn the new features and other features are just like the rose model. It's a great investment and its the best!! The embroidery area is much larger than the rose has, and it sews 800 stitches a minute. OK, I could go on and on. I have one regret, I traded my rose in for the designer 1 and wish I would have kept it. I could of had two embroidery machines running at the same time!!
Posted on Jan 23, 2008
kent581
  • 87 Answers
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Posted on Mar 19, 2009
  • 52 Answers
SOURCE: Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: where can i find a new instruction manual for a
Cut and paste this link into your browser and it will take you to a free copy of the Rose manual.
http://s2.vsmgroup.com/VSM/Husqvarna%20Viking/HVManual.nsf/1fd5659e6f37141041256697003e64c0/8569fb0aa78ab071852575ed00723d7a?OpenDocument
Posted on May 23, 2010
Why is my Husqvarna Viking 425 not forming stitches
1. Make sure there is bobbin thread. 2. It is very important to have the bobbin thread with the right tension setting. This is done by hanging the bobbin carrier with the bobbin inserted from your finger. Bob it a little and it should extend one inch. If it doesn't extend then loosen the tension(counterclockwise) and opposite if it extends too far. 3. Afterwards insert the assembly and pull a couple inches of thread out. 4. Now, thread the top. 5. Adjust the tension to three. 6. Run three inches of thread under the foot and hold unto the thread. At the same time turn the crank towards you. When the needle goes under the plate and back up it should have the bobbin thread with it. Sometimes the first turn doesn't catch the bobbin thread so try a second time. If this doesn't work then change your needle just in case this is the problem. If this doesn't work you will need a repairman adjust the timing.
Oct 29, 2014 | Husqvarna Viking 1
Foot control does not work
Does it work by pushing the Start/Stop button. If so the problem is probably with the foot control. Make sure all connections are secure. You may need a new foot control. Contact your local Viking Dealer and try one of their foot controls to determine if it is indeed the foot control or something else. You can find your nearest authorized Viking Dealer from the Viking website - http://www.husqvarnaviking.com/us Click on Locate a Dealer for your local dealers.
Jan 28, 2014 | Husqvarna Viking 1
I put on the 1/4 inch quilting foot and the machine will not hold the settings, feed: 2 to 2.5 and stitch width 0
This sounds like a stepper motor problem. When you say it will not hold the settings do the feed teeth stop moving? Your feed teeth should be 1mm above the needle plate at the highest setting. Is that working for you?
Dec 15, 2013 | Husqvarna Viking 1
My Viking Rose will start, sew 3 stitches, then stop and raise the pressor foot and beep over and over. Do you have any idea what is wrong?
here's some suggestions
need new needle
needs to be rethreaded top & bobbin
needs to be cleaned under the needle plate & in the bobbin area
for lint
the wrong foot is being used
if none of these suggestion help then the machine may have to
be checked
Sep 09, 2012 | Husqvarna Rose
Husqvarna model 183 foot control no power
anytime the machine does not respond like it's suppose to then it needs to be checked, the foot pedal could have gone bad, or the the sewing machine plug where the foot pedal goes may have gone out
Mar 27, 2012 | Husqvarna Viking 1
Husqvarna ROSE: started going slow after rewinding the bobbin. Now I can hardly move the handwheel, let alone sew anything. It feels as if it has siezed, but when my husband took the 'collar' off,...
Check the bobbin area to make sure the needle is not catching on something with the bobbin unit. Take the bobbin case out and see if it runs. It may be the belt but that's inside. Usually if the belt is off, the handwheel will turn easily but the needle will not go up and down. Suggest service by local authorized husqvarna viking dealer. You can find the nearest dealer from the husqvarna viking website and click on "Dealers" link. http://www.husqvarnaviking.com
Feb 05, 2010 | Husqvarna Viking 1
My bottom thread is all messed up i have a rose
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. What the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 26, 2010 | Husqvarna Viking 1
Fabric stuck when sewing
Several things could be happening. It may be the hook/needle timing. Or it could be the feeddogs are not moving (that's the toothy looking part under the presser foot that moves the fabric). Recommend removing thread and bobbin (needle and presser foot). Slowly move the handwheel and put your finger on top of the feeddogs to determine if they are moving back and forth and are high enough to move the fabric. Check to make sure you had not manually lowered the feed dogs. You may need to take it to an authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Nov 21, 2008 | Husqvarna Viking 1
I can't figure out how to shift the needle to the left
When topstitching using straight stitch the needle position can be adjusted in steps. The stitch width button(+), 0 is the center position, width 6 isleft needle position,width6 mirror image(diamond half clear and half black)is right needle position.
hope this helps, it is from the manual.
Jul 27, 2008 | Husqvarna Freesia 415
Needle doesn't move the problem isn't the foot pedal
I have a Husqvarna #1 that I also love. My needle stopped moving too. I was convinced it was the foot peddle but a repair person sais it was not. I discovered on my own that indeed it is the cord on the foot peddle. I suspect it has a loose wire because when I wiggle it where it connects to the machine it starts working again. Right now this is what I have to do because I can't find a replacement peddle. Can anybody help me find one?
Jul 06, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
